Mid-Atlantic (Sales) VA, DC, and MD
480 whp JDM Front teg
Old Jan 1, 2012 | 03:40 PM
jimmy051702's Avatar
Default 480 whp JDM Front teg
Means of contact: 915-208-3397 text/call or PM
Price: $12500 or trade for a EVO, STI, S2000, M3, RSX TypeS thats it
The car is tuned on 20 pounds by Inline Pro and put down 480WHP.
Aebs t sleeved 2.0L
Wiseco 84mm 18cc dish piston
eagle h-beam rods with arp bolts
arp head studs
type-r crank
Acl main bearings
Acl thrust bearing
Acl rod bearings
new oil pan gasket
moroso oem style pan
Braided return and feet line
New rear main seal
new top end gasket
new type-r oil pump
professional products 68mm throttle body
type-r intake manifold ported to throttle body and head
precision 46mm viand waste gate
hondata 3bar map sensor
precision 600hp intercooler
mishimoto radiator
AEM fuel rail
new distributor cap and rotor
flex a lite fan
red samco hoses
full custom vibrant intercooler piping couplings and clamps
comp stg4 6 puck clutch with pressure plate
comp street light flywheel
Innovative billet mounts
walbro 255
new honda timing belt
4" Vibrant filter
Moroso catch can -12 an
SLS Ramhorn manifold t4 vband
sls vband dump tube
sls 3inch vband downpipe
Cometic Head gasket .030
new type-r water pump
precision 780 cc injectors
ngk blues
access hot internal distributor coil
New full oem honda engine seal/gasket kit
vibrant timing belt tensioner
new alternator
new alternator belt
older mods
new starter
Aem true time cam gears
Greddy Type S blow off valve
turbonetics t70 turbo POLISHED FINISH
Hondata S300
HEAD
Obd1 b16
comp stg 2 turbo cams
CROWER DUAL SPRINGS
CROWER TITANIAM RETAINERS
COMP STAGE 2 TURBO CAMS
SUPERTECH VALVES W/ 3ANGLE JOB
PORT AND POLISHED HEAD
RJ'S 3inch mandrel bend exhaust no cat/no res to a 3-4inch magnaflow ss muffler
interior
Red JDM ITR Front seats
Jdm ITR door panels
mint usdm-r rears
apex aver boost controller with solenoid
aem wideband
eclipse 2din navigation/dvd indash
type-r cluster
Brand new pold audio component speakers all around with alpine amp and amp kit not installed
Also have brand new 55w hid kit that is not installed
suspension
Function and Forum type 2 coilovers New
omnipower lowercontrol arms
Wheels
16in Bronze Rota C10s
NO JOYRIDES and no test drives unless you have cash
http://www.photoshop.com/users/jimmy...133bdf698b169a
The car runs perfect no issues ever and it is a beast I rarely drive it and when I do I do not beat on it at all. The interior is a 9.5 out of 10 and the exterior is a 8 out of 10 there are no Crazy dents but it could use a respray in some areas I am just a perfectionist and hate little things. I love the car and do not really wana sell but I just bought an M5 so probably will never drive it.
Old Jan 1, 2012 | 04:57 PM
bmoresbest781's Avatar
Default Re: 480 whp JDM Front teg
Pics not working
Up for pics
trickmaster505
May 5, 2013 12:58 PM
jimmy051702
May 7, 2012 03:05 PM
STHPERFORMANCE
Nov 1, 2002 08:13 AM
