d16z6 - low compression after head gasket replaced
Old Jan 1, 2012 | 02:04 PM
SolScifen's Avatar
Default d16z6 - low compression after head gasket replaced
ok so heres some back story. sorry if its alot.
my engine kept busting heater hoses and was overheating, suspected after a bit that head gasket was now blown so i replaced it. Put on a dif head that i had picked up. ran fine for a couple days then noticed it started running hot, checked it out and it was leaking from in between head and block. found out the head was not level (found out it was a bad home P&P by guy i bought it from)
Bought new head gasket and put old head back on. now wont start. cylinders keep flooding, did compression test 60 on cyl 1 and 2, 0 on 3 and 4. havent done the oil trick for compression test yet gonna do it tomorrow and see what come up.
my question is is it possible my piston rings are trash now even though i never let it get too hot (prolly 3/4 of the way up) while the unlevel head was on? ill find out for sure tomorrow but just wondering.
Also is there a way i can make sure i have the head on level? ive never had one not sit level until the other one but with no compression on cyl 3 and 4 i have a feeling its not on right.
Old Jan 1, 2012 | 02:41 PM
Former User's Avatar
Default Re: d16z6 trouble
Is the mechanical timing perfect?
Old Jan 1, 2012 | 09:41 PM
Hidenplanvew's Avatar
Default Re: d16z6 - low compresssion after head gasket replaced
Did you put the "Up" side of the head gasket umm "up"?
Did you make sure the block and head were flat? I think theres only like.05 wiggle room
Old Jan 2, 2012 | 08:22 AM
SolScifen's Avatar
yes, timing is right. and its not skipping teeth.
and theres only one way to put a headgasket on lol so ya its on right. i do think the one i bought isnt good quality though.
did the oil in cylinder compression test and results went up so suspecting my rings are just trash now. ordered new ones and a rebuild will be done when all parts get here.
Old Jan 2, 2012 | 08:36 AM
Before you replace the rings, make sure that you just don't have a simple cylinder flooding problem.
Will the engine start after adding a tablespoon of oil to each cylinder?
Is the engine oil saturated with fuel?
With the key in ON(II), do any fuel injectors spray fuel continuously?
Do all 4 spark plugs have bright white spark?
Old Jan 2, 2012 | 08:52 AM
SolScifen's Avatar
Default Re: d16z6 - low compression after head gasket replaced
dont know if it will start, both sets of plugs i have are now fouled out because of the fuel on them. but they will spark, just replaced cap, rotor, wires, and plugs last time i did the HG.
oil has no fuel in it.
and the injectors dont spray continuously, we thought something electrical might keep them spraying too much so we took them out and it would spray off and on like supposed to.
if i get new plugs, add oil to the cylinders and it even tries to start more than before does this mean its something else?
also like stated i think the HG i got this time isnt that good. is it possible its just not sealing right and causing air to seep through? or will even poor quality ones still seal?
Old Jan 2, 2012 | 08:57 AM
What were the compression numbers after adding oil to the cylinders?
Is spark bright white at all four plugs? If so, I'd try starting the engine after adding some oil to the cylinders. If it starts and runs, let the engine fully warm up and then repeat the cylinder compression tests on the hot engine.
Old Jan 2, 2012 | 09:12 AM
SolScifen's Avatar
i think it was about 70-75 on cyl 1 and 2 and maybe around 10 on 3 and 4. will it even turn over with that low of numbers?
i have to go buy another plug to test for spark color
Old Jan 2, 2012 | 09:17 AM
No -- Cyls 3 and 4 are too low. That's not a piston ring problem. You can do a cylinder leak down test to identify where compression is lost from Cyls 3 and 4. My guess is a warped head or even block mating surface.
Old Jan 2, 2012 | 09:27 AM
SolScifen's Avatar
alright, thats something else i was worried about cause it did overheat alot on this head.
i think im going to try and put the head that was recently on cause it did run and see if compression is any better
Old Jan 2, 2012 | 09:29 AM
Old Jan 7, 2012 | 07:02 AM
SolScifen's Avatar
ok so i finally had money to go buy new plugs. tested for spark and only cyl 2 was firing all the time. cyl 4 fired once and 1 and 3 not at all.
i had to record for spark with my phone but i think it was a orange spark.
am i right to think that its gotta be the cap or wires and not the icm since cyl 2 was firing perfect?
Old Jan 7, 2012 | 07:06 AM
Inspect/test the wires, cap, and rotor, and also resistance test the coil. Some auto parts stores will test the ICM for you. Call around to some local stores.
Old Jan 7, 2012 | 08:06 AM
SolScifen's Avatar
tested icm resistance and seems fine about .6 from two terminals and was reading 16.xx resistance to the coil.
wires read #1 9.48, #2 8.92, #3 7.03, and #4 6.48 while set to 20k on the multimeter.
Old Jan 7, 2012 | 08:14 AM
There's no resistance test for the ICM, but there is for the coil.
Old Jan 7, 2012 | 08:23 AM
SolScifen's Avatar
alrite well im gonna take the icm to autozone and see what they say i guess. would it throw a code if it was bad? i dont have any at the moment but just wondering.
Old Jan 7, 2012 | 08:49 AM
Call them. Some AZ employees don't realize that they can find the test on their computer system.
Not necessarily. Sometimes a bad ICM will throw code 15, but this does not always happen.
Did you resistance test the coil (see FAQs sticky for diagram)?
Old Jan 7, 2012 | 04:18 PM
SolScifen's Avatar
got the icm tested and failed. replaced and she runs again.
thanks for all the help man.
Old Jan 7, 2012 | 04:49 PM
betsy96
42
Oct 15, 2013 07:14 PM
civic_jdm
Feb 17, 2005 07:49 AM
fastludeh22
Oct 16, 2003 10:45 PM
AzG35
Nov 15, 2002 07:37 PM
KoRE
Jan 30, 2002 11:35 AM
