Confused by Cat Options
Old Jan 1, 2012 | 03:55 AM
PiRat's Avatar
Default Confused by Cat Options
I have a 01 Coupe 4 cyl with 210k and need a new cat. I am overwhelmed with the right cat for this type of mileage. I do not want to spend 1k on a cat to last 10 years but I dont want something to only last a year.
Ideas on how to approach this decision?
Old Jan 1, 2012 | 04:46 AM
lazlong's Avatar
Default Re: Confused by Cat Options
If you have to pass emissions then OEM is really the only way to go. The aftermarket/hi-flow cats MIGHT pass emissions but, don't a lot of times. OEM are $500 here: http://www.hondapartscheap.com/index...EXHAUST%20PIPE Labor at the muffler shop should be about $100.
Old Jan 2, 2012 | 12:43 AM
MAD_MIKE's Avatar
MM Gruppe B
A few years ago, my wifes Mazda was having emissions issues due to a dying catalyst I picked up a direct fit unit from CatCo. This was prior to the new law that required the CA mushroom stamp of approval for catalysts. That was ~'06 had a Smog test a few months ago and passed no problem.
http://www.summitracing.com/parts/MP...RD&prefilter=1
If a 'shitty' CatCo catalyst can last this long in 'strict' CA then a Magnaflow unit should last you a millennia. PB blaster a couple of gaskets and ~1hr of your time you will be good to go.
BTW you may want to hurry, looks like Magnaflow has released a new 49 state catalyst #46642($380.71), the CA unit is #46615I($380.71), and the old 49 state unit is #22642($166.94).
skaternak
19
Nov 24, 2009 04:07 PM
sicrx69
12
Jul 11, 2007 03:36 PM
ekb16
Mar 1, 2005 09:06 PM
Nocide_Eluded
May 20, 2004 08:26 AM
Thrillhouse
Jul 22, 2003 07:55 AM
