Why are my tires getting chunked on the sides?
Old Oct 8, 2002 | 09:22 AM
FourthGenHatch's Avatar
Default Why are my tires getting chunked on the sides?
I am not sure if it is still happening or not (but I saw a 3'' strip of rubber shredded on the sides today). But the sides of my Kuhmo 712s are chunked on the rear. I just had an alignment and my camber is less than -1* on every wheel. This seems to only happen in the rear though. Any ideas?
[Modified by FourthGenHatch, 6:23 PM 10/8/2002]
Old Oct 8, 2002 | 09:24 AM
EP3_05's Avatar
Default Re: Why are my tires getting chunked on the sides? (FourthGenHatch)
Inside or the outside of the tire? Is it rubbing on anything that would cause the rubber to strip off?
Old Oct 8, 2002 | 09:31 AM
Default Re: Why are my tires getting chunked on the sides? (91civic)
Outsides, not even sure about insides. I looked at the lip on the rear 1/4s and it doesn't look like it could have done the damage. It's really confusing. I also run like 38psi cold so I don't think it's because the pressure is too low.
Old Oct 8, 2002 | 10:55 AM
big pete's Avatar
did you roll your fenders?.....the tire might be scrapping against the fender
Old Oct 8, 2002 | 11:17 AM
E-AT_me's Avatar
Default Re: Why are my tires getting chunked on the sides? (big pete)
um, 38 psi is like 10 plus the stock psi.. i normally run 32-34 on the street.
Old Oct 8, 2002 | 02:00 PM
shotty's Avatar
Default Re: Why are my tires getting chunked on the sides? (Rexman)
Tire pressure is different with all tires. Anyway. On hard acceleration your car is "squatting" which draws the rear end down and the front end up. Or a hard bump will also cause your tires to rub on the inner fender. You need to roll the lip in the rear fender wells. That will take care of your problem.....
Old Oct 8, 2002 | 02:04 PM
ImportHatch's Avatar
Default Re: Why are my tires getting chunked on the sides? (shotty)
prob rubbin on the fender while turning and hitting a bump....
Yager-
Old Oct 8, 2002 | 02:37 PM
pelotudo's Avatar
Default Re: Why are my tires getting chunked on the sides? (ImportHatch)
Yager-
Yup, I'm doing that. I'm just wondering how long before I am going to be buying a new Kumho tire. It's like a knife cutting in to the outside of the tire every time I nail a bump.
jB
Old Oct 8, 2002 | 02:57 PM
E-AT_me's Avatar
Default Re: Why are my tires getting chunked on the sides? (PelowisheshewascoolTudo)
i have a rubber piece on my fender lip that just rubs the tire and doesn't cut in.. but it's stock...
i know tire pressures are different per tire, but that much! i dunno... maybe so.. can't remember what i had my 16's at, but my 15's are at 34..
btw, love the avitar..... she's hot....
Old Oct 8, 2002 | 03:54 PM
bfrank81's Avatar
You either have to have roll your fender or have it jacked out by a body shop. If you roll the fender you stand a chance of rippleing the rear 1/4 panel which will look like poop.
But, on the other hand I had to pay $400 for a body shop to roll the rear fenders so they do not touch the tires even under the hardest turn or bump.
So those are your choices but I would assume that that is your problem.
Old Oct 8, 2002 | 04:18 PM
Default Re: Why are my tires getting chunked on the sides? (bfrank81)
How come I couldn't take a hammer and just tap around the lip to bend it? Or will that **** things up bad?
Also why has it started doing this now? Could it be my rear discs? Did the integra one throw off my offset?
[Modified by FourthGenHatch, 1:21 AM 10/9/2002]
Old Oct 8, 2002 | 04:37 PM
bfrank81's Avatar
You could do it with a hammer it might have ripples when your done though. I would guess that adding the teg brakes did affect your offet and that could be why you are now rubbing fender.
Old Oct 8, 2002 | 05:27 PM
E-AT_me's Avatar
integra discs i think throw out the rear like 1/8 inch or so on each side.. i think...
GSRkrod
Honda S2000
17
Oct 13, 2009 05:15 PM
LX4CYL
Apr 12, 2005 01:17 PM
fanatic
Nov 22, 2002 07:30 PM
vtec.dc2
Oct 9, 2002 09:59 PM
comptechgsr
May 18, 2002 09:44 PM
