89 CRX HF/ Beefed b18a1 swap
Old Dec 31, 2011 | 06:28 PM
Thorshammer's Avatar
Default 89 CRX HF/ Beefed b18a1 swap
Heres what I know about the motor...
Block= bored .50mm oversize, shaved deck height .020mm
Crankshaft= LS Crank micropolished + magnafluxed for cracks.
Rods= Manley Sportsmaster.
Forged from aircraft quality 4340 material
Entire beam and cap are profiled to remove stress
risers and render the lightest possible rod
Shot peened after machining to Mil specs and 100%
individually magnafluxed
Cap fasteners are 7/16" ARP 8740 cap screws
Premium Ampco pin bushings
horsepower range for these rods is 800 H.P.
Pistons=Manley Platinum Series
2618 high strength material; lightweight design
Premium Chrome Moly pin included
Perfect ring groove to skirt squareness
Pressure balance groove
Premium Steel top ring sets and Round Wire locks included
Recommended piston clearance .0040" measured 1.100" from the bottom of the oil ring
Oil pump = OE Factory Acura new pump
All bearings= Cleavite
All seals = Comtect or OE factory
Cyl Head= all guides are new
All Valve are new Chrome valves
Timing belt new OE
Waterpump New OE
Camshafts= Stock
Cam Gears = Crower adjustable gear
So far I have...
ls 5 speed trans, flywheel,pressure plate
GSR Intake, exhaust manifold and fuel rail
Axles, ecu, harness
Engine mounts
cold air intake
JDM distributer
What I have ordered
skunk2 66 mm throttle body
skunk2 coilover/strut assembly
rear lower control arm, front upper control arm
new radiator and fans
plugs wires,tps etc....
My question is this.....
How should I set this engine up to be the most reliable daily driver? What fuel injectors do you recommend and would you change out the cam and springs to get the most performance from this motor?
Thanks in advance for you help.
Old Dec 31, 2011 | 07:33 PM
Default Re: 89 CRX HF/ Beefed b18a1 swap
Bump before attending the masses in the New yrs drinkathon.
Old Jan 1, 2012 | 05:11 AM
crvtectim's Avatar
Need more info. What's the CR? What fuel do you plan to run? How do you plan to bolt up the GSR intake manifold to the B18A1 head?
Old Jan 1, 2012 | 10:27 AM
CR? Explain plz.
Premium fuel, The intake manifold is off of my friend James gsr motor. It bolted right to the intake no problem.
Old Jan 1, 2012 | 10:36 AM
Neomoogle's Avatar
Originally Posted by Thorshammer
CR? Explain plz.
I think he is talking about the Compression Ratio.
Old Jan 1, 2012 | 10:44 AM
With the mods done on the motor I dont know what the compression ratio is. I assume its fairly high lol
Old Jan 1, 2012 | 11:11 AM
crvtectim's Avatar
Yes, compression ratio for the pistons being used. The bolt pattern for the intake on a GSR is unique. Are you using a GSR head on a B18A1 block?
Old Jan 1, 2012 | 11:35 AM
That is quite possible. I bought the motor locally in Sacremento. It was built for the guys son but he totalled his integra before hitting 5k miles.
James, my mechanic was shocked the intake fit but didnt explain why.
Old Jan 1, 2012 | 02:19 PM
Anymore opionions on how the motor was rebuilt?
Old Jan 1, 2012 | 03:01 PM
crvtectim's Avatar
Yea, I would def contact the previous owner for more details. It may be a high comp motor that requires 93 octane or higher or even E85. Also, find out if they assembled it with ARP head studs and/or rod bolts. A few more details, and we can point you in the right direction with the swap and tuning.
Old Jan 1, 2012 | 03:13 PM
Ron fully suggested, actually stated, to run high octane only. It does indeed have arp head studs and rod bolts.
Old Jan 1, 2012 | 07:24 PM
I'm buying the injectors and such this week. Would love some input here fellas. I totally trust my mechanic but would love to throw some ideas and input in his direction.
Old Jan 2, 2012 | 03:55 AM
crvtectim's Avatar
**** man, I thought you were the mechanic. Owned by reading. Well, if your mechanic doesn't know if the motor has a GSR head on it or not, find another mechanic! Or do the swap yourself, and put the money you saved by doing the work yourself towards a good tune. Find a tuner and pick their brain on what cams and valvetrain components will suit your build best. You should also consult your tuner about the fuel injectors before you run out and buy some.
Old Jan 2, 2012 | 05:33 PM
lol James did tell me today the motor has a gsr head on it. Seeing that he has built around 30 or so I'm sure he knows what hes doing lol
Now could anyone give me an honest opinion on this motor? My biggest reason for the swap is I carry 4-500lbs in extra stereo equipment and I'm tired of being passed by rv's going up hill.
I'm not concerned about top end speed. Im more interested in the low end torque.
Old Jan 2, 2012 | 06:15 PM
Heres a quick walk around of the car and and idea of the extra wieght I haul around.
http://youtu.be/Pa1mfdliUNk
My 9-5 job is building subwoofers for DC Audio and rolling to competitions on the weekend. Currently the loudest CRX on the west coast. Now I want to make it go fast and look good.
Old Jan 2, 2012 | 06:25 PM
Misc pics from the wings west body kit swap
Old Jan 2, 2012 | 08:29 PM
Bump
No one has any opinion?
Old Jan 3, 2012 | 10:55 AM
I'm told Cr is 9.6:1
Old Jan 3, 2012 | 04:13 PM
Thanks to the 2 gentlemen who replied. I guess I'll just leave it up to my boys at Lake County Car Audio in Upper Lake Ca.
End of thread
Old Jan 3, 2012 | 04:35 PM
crvtectim's Avatar
The swap will easily tote the extra weight and a 9.6:1 cr is boost friendly should you decide to add a turbo down the rode. I'm not a fan of body kits, especially when they're stuffed with chicken wire lookin' ****. But if I had to choose a kit, the Wings West kit isn't that horrible. Good luck with your build.
Old Jan 3, 2012 | 04:48 PM
ryanmh22's Avatar
i gotta agree im not a fan of body kits but its your car, what else you have planed for it?
Old Jan 3, 2012 | 06:43 PM
Once the engine and suspension ( went with skunk2 struts,springs and camber kit) are done within the next 2 weeks or so It'll get painted deep concorde midnight blue and get wrapped by my friends shop here in Reno. You can check out his truck @ www.dcsoundlab.com.
On the hood will be an ornate pic of Thorshammer Mijolnr with DC Audio on the sides. There will also be advertisements for Lake County Car Audio and Offroad (engine and suspension work ), Singer Alternators ( Hooking me up with a dual alt bracket for 400+amps of current), Kinetik Batteries(Battery Sponsor).
I'm still debating on what to run for DbDrag Finals in March but it will either be 2 or 4 lvl 5 12's, 2 9k amps, 3 multicell batts.
This is how i spend my weekends
http://youtu.be/JTxFoxL34oc
This is how I treat my subs
http://youtu.be/8NAmMorj1FQ
This is my baby. Was the loudest Trunk Vehicle in the World in 4 diff competing orgs at the same time for 4 yrs. Working on regaining that Title very shortly lol
http://youtu.be/d4mOK852T_0
Old Jan 3, 2012 | 10:29 PM
4drEF's Avatar
Keyboard Humorist
what?
WHAT?
I ... can't... HEAR YOU!
WHAT!?!?!?!
LOL!
No heart monitor?
Old Jan 4, 2012 | 05:32 PM
Can you speak a lil louder I cant quite hear ya!!
Old Jan 6, 2012 | 07:41 AM
1 more week and the swap will happen.
