car only going past 3000 rpm's
i had this problem on my k20 set up. my tps sensor was bad so that could be it but also when i wired the conversion harness to the oem harness one of the wires was cut so i re spliced it and the problem went away. i think the color of the wire was yellow with a green stripe. if was one of the wires that would be used on the 3 plugs that go into your kpro. i believe a tps sensor should read a voltage of .5 at idle and 4.5 at wide open throttle. but maybe you have the same problem i had.
