97 Civic tire fit question
I am replacing my 205/55 15 Nitto Neogens but haven't been able to find a replacement in the same tire size. I am concerned that 205/65 15 will rub. My vehicle is a completely stock 97 Civic with 2000 si alloy 15s. If those tires aren't going to work, what is the max tire size I can use without alteration? Will I need to step back down to a 195 width to increase diameter? Any info that will relieve my anxiety of buying the larger tires will be appreciated. Thanks
Discounttiredirect.com and tirerack.com mostly. I shop there so I can read reviews and comments. I should say I haven't found many tires that size that I like. The Neogens I have perform as long as there is no snow or ice, I'd like a true all season tire. Also looking for something with better treadlife. The Hankook Optimo H727 looks like an inexpensive option but now I am trying to find out which tire size is right for me.
Nice. I believe I read an article early on in my search that gave negative reviews for Direzzas but I like the S-Drives. What size do you use? Are you suggesting I give up the search for a different tire size all together and get whatever I can in the 205/55 15?
I run 16s.
You can get the S-Drives in that size.
http://www.ebay.com/itm/4-NEW-Yokoha...item43ac1356f9
What model Direzza are you referring to? The DZ101's and D1 Star Spec's are both very good performing tires. I've had both.
We recommend 205/50R15 for your model year to keep the overall tire diameter close to stock (23" overall), the year 2000 Civic used 195/55R15 as OE, so the 205/50R15 would be fine on that car as well.
stu2211
Mar 17, 2003 09:42 PM
