97 Civic tire fit question
I am replacing my 205/55 15 Nitto Neogens but haven't been able to find a replacement in the same tire size. I am concerned that 205/65 15 will rub. My vehicle is a completely stock 97 Civic with 2000 si alloy 15s. If those tires aren't going to work, what is the max tire size I can use without alteration? Will I need to step back down to a 195 width to increase diameter? Any info that will relieve my anxiety of buying the larger tires will be appreciated. Thanks
Re: 97 Civic tire fit question
Where are you looking? Found 140 different matches for this tire size on Ebay alone.
Originally Posted by grumblemarc
(Post 46602194)
Originally Posted by 6gen
(Post 46602088)
I...haven't been able to find a replacement in the same tire size.
(Post 46602330)
The Yokohama S-Drives are more than a suitable replacement. I run these. Direzzas have been reported to be a capable tire.
I run 16s.
You can get the S-Drives in that size. http://www.ebay.com/itm/4-NEW-Yokoha...item43ac1356f9 |
(Post 46602390)
Nice. I believe I read an article early on in my search that gave negative reviews for Direzzas but I like the S-Drives. What size do you use? Are you suggesting I give up the search for a different tire size all together and get whatever I can in the 205/55 15?
What about runing a 205-50-15?
We recommend 205/50R15 for your model year to keep the overall tire diameter close to stock (23" overall), the year 2000 Civic used 195/55R15 as OE, so the 205/50R15 would be fine on that car as well.
Originally Posted by toyomatt84
(Post 46603078)
What model Direzza are you referring to? The DZ101's and D1 Star Spec's are both very good performing tires. I've had both.
(Post 46639764)
DZ101s. The Z1s are out of my price range for the moment.
Go to treadepot.com , they have a bunch of different tires in plenty of sizes. That's where I buy my tires, usually get them cheaper than anywhere else.
