WILL B18 INTAKE MANIFOLD FIT ONTO A B16A2 ENGINE (U.K.)?
Any comments please?
Just need to know will fit fit? Are the mounting points the same and will it give any performance benifits?
The non vtec integra and the crv intakes are different from the civic si intake and different from the gsr integra. The type r integra intake is a "ported" version of the Civic si intake.
You have 3 bolt patterns, the different patterns are not interchangeable, but I've seen a Type R manifold modified to fit on a GSR if I recall correctly.
If you can't drill and port match to make something fit, you can make an adapter plate. They put the K20 RSX type S manifolds on Honda Prelude 2.2 liter engines sometimes to gain power by using an adapter plate made from 1/2" thick aluminum with holes so it mounts on the Prelude engine and then studs let the manifold bolt to the plate.
These are tuned length, engineered for each engine's requirements.
saunders400
Dec 31, 2011 03:37 PM
Alfspeed
Aug 14, 2009 06:45 AM
dsm_mikey
Feb 26, 2004 09:30 AM
