Interior Lights Complete Out 2001 Accord Coupe Ex 4 cyl
Old Dec 31, 2011 | 06:06 AM
PiRat's Avatar
Default Interior Lights Complete Out 2001 Accord Coupe Ex 4 cyl
Dome lights, glove box, visor mirror, and map lights do not work although bulbs have been changed. I confirmed that #11 fuse is fine but not sure if other fuses might affect this. The door lights and trunk light works. The sunroof works but basically no lights overhead work.
HELP!
THank you
Old Dec 31, 2011 | 07:07 AM
el crapitan's Avatar
Default Re: Interior Lights Complete Out 2001 Accord Coupe Ex 4 cyl
use a 12v test light and test for power at the dome light fuse. if power exists, use the test light at the dome light. supply your own ground through the test light. if you have power supplying your own ground, problem is with the circuit ground
Mike Arvai
Lighting
Nov 15, 2015 06:27 PM
Big Bull
Aug 28, 2012 08:45 PM
TrackRat
Jul 19, 2010 01:23 PM
175Shot4Door
Jan 22, 2006 06:01 PM
