O2 sensor location for 93 Civic LX
I just ordered a 4-2-1 header for my 93 LX. 2 reasons... 1, the prevouse owner that put in the z6, reused the exhaust manifold from the d15 that was in it... and 2, that manifold has a crack and is leaking where it meets the down pipe.
Looking at the pic of the header, there are 2 places for the O2 sensor, almost right of the engine, only reading one of the cylinders and one back at the end, near the joint to the cat. does it make any difference rather its reading just one or all four. If it does, would it be a good idea to order an O2 extention to be able to reach the back bung?
ok so i am assuming u ordered a chepo ebay header one of the o2 sensors goes in the fist bung u cap off the 2nd bung and u run ur 2nd o2 sensor behind the cat unless u dont have a cat which means you will need to get one because because if im not wrong the b15 has the cat on the manifold
96 and newer have the cat with the manifold, mine is more or less under the shifter (that general location anyway)
Actually, it is like a $50 ebay header but even the megan racing 4-2-1 headers have the same 2 bungs. Only reason i went cheap like this is i didnt see the point of getting a "good" one when im planning on turboing is in the next 12 months or so... i just need this to fix the exhaust leak
I'm assuming you got something similar to this (ignore the test pipe in the middle):
If so use the bung location at the end. If you are only monitoring 1 cylinder by using the other bung it's not going to give your ECU the most accurate reading and could throw off your mileage and hinder performance. You may have to extend the O2 wiring depending on how much length you have. It's a 4 wire O2 not a two wire.
and my bad you are right about the exhaust manifold forgot that they changed that
DC2*Integra
Aug 25, 2005 06:21 AM
jds_06
Jan 18, 2005 09:36 AM
