Problem with temp gauge and heater controls
Old Dec 30, 2011 | 02:36 PM
fernando.'s Avatar
Default Problem with temp gauge
Hey guys, just picked up a beater, it's a 97 DC4 in really good shape but has a few problems.
1. Fixed!
2. Fixed!
Thanks in advance.
Old Dec 30, 2011 | 02:47 PM
mark@silbernage's Avatar
Default Re: Problem with temp gauge and heater controls
Is the radiator full? Tho, if it goes to zero it may be a loose wire...
On the blower, if it only works on 3/4 I'd look at the resistor... the MAX setting bypasses it completely, and the lower settings go through different parts of it. Sounds like its fried for the lower parts. Since it works at all, the motor sounds like its fine.
Old Dec 30, 2011 | 03:14 PM
fernando.'s Avatar
Haven't found a chance to check to see if the rad is full or not as I just brought it home tonight and it's dark and cold out already, lolol.
As for the climate control, already figured out the problem, it's the resistor like you said.
Old Dec 31, 2011 | 02:12 PM
fernando.'s Avatar
Anyone else? Could it be the thermostat?
Old Dec 31, 2011 | 06:59 PM
willywilly's Avatar
i had a similar problem. the gauge would go up only about a quarter and when i drove it would fall back to zero. changed out the thermostat and now it stays just to the left of center.
Old Jan 1, 2012 | 10:18 AM
fernando.'s Avatar
Going to pick up a thermostat tomorow and give it a shot.
Paulie10
Jun 13, 2009 03:17 PM
illestsilek
Nov 10, 2008 10:10 PM
IntegraLova
Apr 17, 2008 02:43 PM
ButterMule
Nov 27, 2004 10:19 AM
FredoTheChimp
Dec 31, 2002 03:48 PM
