Need help with Crank Identification (please see pics)
Old Dec 30, 2011 | 01:21 PM
Bwhit12's Avatar
Default Need help with Crank Identification (please see pics)
Hey H-T,
I'm looking to get some clarification on two cranks I have. I have been looking for the past few days on how to identify the cranks, but I have come up with nothing. If you guys could point me in the right direction or if you happen to know what these cranks are that would be great.
Here are the pictures of the cranks:
Crank #1
Crank #2
I appreciate the help!
Thanks
Billy
Old Dec 31, 2011 | 08:32 AM
Bwhit12's Avatar
Default Re: Crank Identification
Any input??
Old Dec 31, 2011 | 10:55 AM
NotAJDMFanBoy's Avatar
Default Re: Need help with Crank Identification (please see pics)
you need to measure the stroke, the distance the rod part moves vertically. 89mm is ls/b20. 87.2mm is gsr, and there's a b20 prelude with a 92mm stroke, and there's something shorter for the b16. The width of the rod journal differs between a couple cranks but that basically differentiates vtec and non-vtec I believe.
Old Dec 31, 2011 | 11:52 AM
dem0nk1d's Avatar
Honda Crankshaft Identification
The AERA Technical Committee offers the following information on crankshaft identification for Honda four cylinder engines. Generally, there are no reliable casting numbers on Honda crankshaft and physical identification is required if the engine family is not known. In some instances, there may be a difference in crankshafts for the same engine family. Refer to the chart below to assist in
crankshaft identification, all dimensions are given in inches.
Total Length Flange Bolts
Nose Dia. Counterweights
Main Size Oil Pump Drive
Rod Size cc Displ.
Stroke Year Engine Model
16.5 .865 1.968 1.574 2.992 6 4 No 1169 1972-79 EB, EE
16.5 .865 1.968 1.574 2.992 6 4 No 1238 1972-79 EB, EE
16.6 .865 1.968 1.574 3.228 6 4 No 1300 1980-83 EJ, EN
16.6 .865 1.968 1.574 3.228 6 4 No 1335 1980-83 EJ, EN
16.6 .865 1.968 1.653 3.405 6 4 No 1488 1974-83 ED, EM
16.6 .865 1.968 1.653 3.396 6 8 No 1601 1980-83 EP
16.6 .865 1.968 1.653 3.661 6 8 No 1599 1976-78 EF
16.6 .865 1.968 1.653 3.700 6 8 No 1751 1980 EK, W/10mm Fly/Bolts
16.6 .865 1.969 1.653 3.700 6 8 No 1751 1981-83 EK, W/12mm Fly/Bolts
17.5 .865 1.771 1.495 3.326 6 4 Yes 1493 1988-92 D15B1, D15B2
17.5 .865 1.771 1.574 3.070 6 4 Yes 1342 1984-87 D13A2, EV1
17.5 .865 1.77I 1.653 3.405 6 4 Yes 1488 1983-87 D15A1, EW1, EW3
17.5 .865 1.771 1.653 3.150 6 4 Yes ??? ??? EXPORT
17.5 .865 1.969 1.653 3.405 6 4 Yes 1488 1983-87 D15A1, EW1, EW3
17.5 .944 1.771 1.653 3.405 6 8 Yes 1488 1983-87 D15A1, EW1, EW3
17.6 .865 1.771 1.495 3.070 6 4 Yes 1342 1984-87 D13A2, EV1
17.6 .865 1.771 1.653 3.326 6 8 Yes 1493 1988-92 D15B1, D15B2, D15B6
17.6 .865 1.968 1.574 3.070 6 4 Yes 1342 1984-87 D13A2, EV 1
17.6 .865 2.165 1.771 3.543 6 8* Yes 1590 1988-93 D16 SERIES
17.6 .865 2.165 1.771 3.543 6 8**Yes 1590 1988-93 D16 SERIES
17.6 .944 1.771 1.495 3.326 6 4 Yes 1493 1988-92 D15B1, D15B2, D15B6
17.6 .944 1.771 1.653 3.326 6 8 Yes 1493 1988-92 D15B1, D15B2, D15B6
17.6 .944 2.165 1.771 3.543 6 8**Yes 1590 1988-93 D16 SERIES
17.6 .944 2.165 1.771 3.543 6 8* Yes 1590 1988-93 D16 SERIES
17.8 .984 1.968 1.771 3.582 8 8 No 1955^ 1986-89 BS, BT, A20A1, A20A3
17.8 .984 1.968 1.771 3.582 8 8 No 1955^^ 1986-89 BS, BT, A20A1, A20A3
18.5 1.102 2.165 1.771 3.740 8 8 Yes
18.7 1.181 1.969 1.771 3.543 7 8 Yes
19.9 1.102 2.165 1.771 3.503 8 8 Yes 1834 1985-88 B18A
18.9 1.102 2.165 1.889 3.740 8 8 Yes 2056 1990-91 B21A1
19.6 1.181 1.968 1.771 3.567 8 8 Yes 2259 1992-94 B23A1
19.6 1.181 1.968 1.989 3.740 8 8 Yes 2156 1993-95 H22A1
* All Counterweights Are 1.750 Long.
** Second Counterweight is 1.125 Long.
*** Oil Pump is Two Flat Areas Machined Between #1 Main and Pulley
Snout
^ Has 11.5mm Crankshaft Pulley Bolt 11.5mm.
^^ Has 14mm Crankshaft Pulley Bolt 14mm.
swirve1
Jan 6, 2010 06:23 AM
amios
Aug 14, 2009 11:41 AM
hoskos
Jan 29, 2006 09:39 PM
Power Rev Racing
Jun 23, 2005 06:43 PM
hybridpatient95
20
Jan 4, 2005 05:07 PM
