Light front end damage
Old Dec 30, 2011 | 01:12 PM
njteggy's Avatar
Default Light front end damage
My buddy recently pushed back his rad support on his eg hatch not to bad but bad enough that the hood cant close (cf hood flexed but never cracked). Long story short he bought a replacement rad support (AM) and gave me the car to see if I can fix it, I've never done rad support replacement but I gave it a shot. I drilled out the spot welds and got the support off and when mocking up the new one I noticed that I could line it up one the one sides frame rail but the other side is just out of reach by no more then 3/4 of an inch. Any ideas on what I could do to get it in place? My other friend suggested using tow straps and strapping the front end tight till it fit but I'd rather not do that. Thanks for any helpful input.
Old Dec 30, 2011 | 04:04 PM
Hawkze_2.3's Avatar
Default Re: Light front end damage
Is the car frame bent or does the rad support not fit (poor quality)?
Old Dec 30, 2011 | 05:02 PM
njteggy's Avatar
The frame rail doesn't look bent whatsoever. It might be the rad support. I managed to force it into place and bolt it down but I'm not sure if it's supposed to just slip right on or you need to give it a little force. I put the bumper and fenders on and everything looks like it lines up besides the gap between the bumper and hood (not overhang) so idk
Old Dec 30, 2011 | 11:43 PM
Dontoh's Avatar
it should slip right on.. before doing this you need to find out if its poor quality or if the frame is bent.. if the frame is bent you will need to have it bent back properly, or atleast do it yourself to spec.. take measurements off an eg that you know is straight and compare it
Old Dec 31, 2011 | 12:22 AM
njteggy's Avatar
I have no other eg that I can take measurements from
Old Dec 31, 2011 | 09:22 AM
Dontoh's Avatar
no friends or anything that can help ya out?
i can run down and take some measurements for you if you want.. just let me know where EXATLY you want them taken from
Old Dec 31, 2011 | 12:42 PM
njteggy's Avatar
If you could just frame rail to frame rail. And none of my friends got eg
Old Dec 31, 2011 | 12:59 PM
Dontoh's Avatar
i got 3 ft (36") +/- 1/4"
from here on the pass. side
to here on the drivers side
Old Jan 2, 2012 | 11:53 AM
njteggy's Avatar
ok the measurements check out and I bolted everything on. Didn't spot weld the rad support to see how everything looked the hood and fenders have no gap in between but theres a gap between the hood and the bumper of about 3/4th of an inch. It's not an overhang its just a straight gap. This is after I lowered the hood latch down as far as it could go and the gap still remains. I also adjusted those little rubber stops but nothing is helping. I'm beginning to believe it is the rad support.
Old Jan 2, 2012 | 02:48 PM
Dontoh's Avatar
the rubber stops AREN'T an adjustment.. they are there to hold your hood still so its not rattling down the road.. try adjusting your hood latch, that is how you make that kind of adjustment.. how are the gaps from the hood to fenders. are they even?
on an eg, i THiNK(?) some hood to bumper gap is normal, i could be wrong though, but im pretty sure.. you have any pictures btw?
Old Jan 3, 2012 | 06:06 AM
njteggy's Avatar
The hood latch is all the way down. Ill post some pics after work
Old Jan 3, 2012 | 06:35 AM
speedooo's Avatar
Sounds like a poor quality replacement. Try finding a junked eg and cut the rad support off
Old Jan 4, 2012 | 01:56 PM
njteggy's Avatar
Here is a pic. Dont mind the ambers those were just placed in there.
Old Jan 4, 2012 | 02:49 PM
Dontoh's Avatar
ya that looks high.. is it sitting high all the way back? like high compared to the fenders?
Old Jan 5, 2012 | 06:12 AM
njteggy's Avatar
No the front is lined up on top with the fenders theres just that gap -_-
Old Jan 5, 2012 | 04:12 PM
Dontoh's Avatar
what parts are aftermarket? it may just be that they're poor quality. 90% of the time aftermarket body panels don't line up right without adjustments
Old Jan 6, 2012 | 06:02 AM
njteggy's Avatar
The rad support he bought is aftermarket. I'm going to tell him to get oem rad support
Old Jan 6, 2012 | 10:01 AM
Dontoh's Avatar
yeah, best bet.. or order one from a more reputable deal.. my rad support is aftermarket and it fits like a glove, was expensive but def cheaper than oem.. or if buying someone new isn't an option, start bending and breaking **** to make it fit lol
Old Jan 8, 2012 | 03:14 PM
njteggy's Avatar
where did you order your rad support from
Old Jan 8, 2012 | 05:03 PM
Dontoh's Avatar
honestly, can't remember.. i ordered through my paint supplier.. i want to say it was keystone though
c.dub
Aug 1, 2008 02:53 PM
MJL
Oct 14, 2005 07:49 PM
Subtle1
Apr 25, 2005 09:27 AM
xpsonic
11
Aug 6, 2002 09:15 PM
