Spark Plug Cable with Ground
Since there is not a lot information about this item. So I just create in here. well almost forget to wish you all happy new year. since i use NGK R09 cable. Well is pretty good and no problem at all. But I was wonder that anyone being use the spark cable with ground kit like spoon (is ngk with ground) or ngk with gground kit. I'm not talking nology cable here... many negative critics. below I attached this picture is the brand from Japan T.M works spark plug with ground cable and here is the benefit when using it....
http://www.tmworks-web.jp/images/sspec/wspcdc2.pdf
so any good increase from ngk r09 to spark plug with ground and any problem could exist like spoil the distributor coil.... any comment just write in here thank you
I'd stick with the OEM wires. They're proven to last and be one of the best options. That style has been around for a while, google "Nology Hotwires".
