Manual Transmission - won't go into 3rd gear
Old Dec 29, 2011 | 11:23 PM
Freckles's Avatar
Default Manual Transmission - won't go into 3rd gear
Okay, before I make assumptions and go by what everyone is telling me, I need some help.
My D16z6 is not letting the 3rd gear go in. every other gear goes in fine, reverse i have to rev it a little to get it in without grinding, but 3rd won't go in at all... What could the problem be?
Old Dec 30, 2011 | 12:13 AM
Mashimaro's Avatar
Default Re: Transmission Problems.
Possible you have a bent fork. Odd that you have to rev it a bit to get into reverse.
Old Dec 30, 2011 | 05:31 AM
Freckles's Avatar
Is that the only problem that it could be? Is there any way to diagnose this ****? I don't want to buy a new transmission on monday, and it could end up being something else..
Old Dec 31, 2011 | 08:55 AM
Kohen's Avatar
i gotta s20 ex/si tranny sittin' around
Old Dec 31, 2011 | 08:57 AM
Former User's Avatar
Is the MTF low? When was it last replaced?
Please place simple technical questions directly into the thread title -- Title edited.
Old Dec 31, 2011 | 09:29 AM
94EG8's Avatar
Seagull Management
No, but if it goes into every other gear fine then either way it's an internal transmission issue.
Pull the transmission and take it apart. There is no crystal ball for this stuff. If you work on the same stuff day in and day out yes after a while you can take an educated guess and usually be right but every once in a while you'll see something totally new.
There is something internally wrong with the transmission, if you're just planning to replace rather than rebuild then you wont be wasting your money unless you buy a junk replacement tranny.
Old Dec 31, 2011 | 09:32 AM
94EG8's Avatar
Seagull Management
Low MTF wont usually cause issues with 3rd Ron, normally what you will see is the transmission wants to pop out of 5th gear.
kongzilla
May 16, 2008 07:39 PM
vietnogi
Feb 2, 2006 11:36 AM
H2nr
Jul 12, 2004 08:52 PM
cr-x si
Apr 14, 2003 08:34 PM
zijiejijeijrkjk
Jul 30, 2002 04:15 PM
