would the wrong ecu cause this
I have a lsvtec but its running a ls ecu. If you give more the 30% throttle it bogs down and stays at 3K but if you ease into it goes up in the rpms fine. The map and tps are good so I was wondering if the worng ecu would cause this???
Cool Cool Island Breezes. BOY-EE
The wrong ECU can cause it if some sensor wasn't properly registering due to incorrect pin location. However, in your case, no....the ECU being incorrect isn't causing it. Are you SURE that the TPS and MAP are plugged in properly? Also, check your distributor wiring. I remember there being 2 blue wires...one was slightly lighter blue. Mix those two up, and the TDC won't work properly.
Is there a check engine light on? If so...for what?
Are all the sensors plugged in properly?
Why did you do a LS VTEC but then...have a Non VTEC ECU. You're esentially back to having a non VTEC car again.
Because he has an LSVTEC (not sure if it's a GSR head or not), but if it is a gsr he needs it for the secondary runners (I know you know that). Plus running the correct VTEC ecu for the head you are using is the way it should be done. I know the PR4 wired for VTEC will work, but I don't recommend doing it.
Any B series OBD1 ECU wired for VTEC or IAB will work fine, provided it was done by someone who knows what they're doing. I've got a socketed p75 and it works great on my GS-R.
OP, I recommend sending your ECU off to Phearable.net or Xenocron.com and having it chipped, socketed, and modded for your needs (provided it's OBD1). Both those guys can also give you a basemap that will let you run more or less safely until you can get a proper tune.
eric5984
11
Apr 23, 2019 10:53 PM
nick91civicsi
Engine Management and Tuning
Oct 25, 2009 03:27 PM
