'98 Civic is missing, rough idle and backfires
so was on my way home and went to accelerate and all i got was spitting and spudering ... was only at 3/4 to wot but now its if i just press the gas ... car starts fine .idles rough and sounds like a WRX ... i have changed rotor button , cap , plugs , plug wires, fuel pump, coil, fuel filter was done a few months ago .... what amp i missing ... car will barely stay running now... but starts up fine .. i have spark at all 4 plugs and the plug wires are in the right spots ... when i looked at the spark they did seem to be a little orangish ... and if i get the revs up it will backfire through the intake and exhaust ... and sometimes i can just hold it WOT and it wont go over 2k rpms
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-pull-cel-d4-srs-abs-codes-code-lists-1901557/
Read this, and do it now. We can't help you, if we don't know the codes shes throwing.
what year is your car? obd1 or obd2?
http://www.civicforums.com/forums/17...code-rant.html
for obd1 CEL ^^^
for obd1 CEL ^^^
Is this the same issue as this?
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/sluggish-d16y8-what-could-problem-3001864/
