Gsr problems please help
Old Dec 28, 2011 | 09:31 AM
Boosted96gsr's Avatar
Icon2 Gsr problems please help
Ok guys so heres my set up, so my 96 gsr has a full greddy turbo kit with 550 injectors and my ecu tunned at 8lbs everything else is completely stock, the other day I was racing and one off the vacuumm hose came off and it started idling really bad, so then the next day I thought I fixed everything and now it idles at low rpm and will eventually turn off; it also backfires really really bad what could be the problem?? Please help
Old Dec 28, 2011 | 04:27 PM
01oemTeggy's Avatar
Default Re: Gsr problems please help
Any check engine lights? What are the codes?
Did you bleed/add the coolant after the hose came off? Air in coolant system causes it to idle low.
Old Dec 28, 2011 | 04:44 PM
fcm's Avatar
fcm
Old Fart
Backfiring is an indication that timing is off, or unburnt fuel in the exhaust system, so poor or intermittent no spark.
I would check the timing first, both valve timing, [maybe skipped a tooth] and ign. timing, [ possibly a loose distributor]. 94
Old Dec 28, 2011 | 09:55 PM
no none of my lights came on and i figured that by just putting the hose back on will make everything go back to normal
Old Dec 28, 2011 | 09:59 PM
b20bFourDoorCivicLX's Avatar
that happend to me one time, and it was my spark plug wire, of the 4 wires, came loose and it would idle like an evo, and back fire
Old Dec 29, 2011 | 08:36 AM
fknfast's Avatar
its not firing on all cylinders or timing is fubar
Old Dec 29, 2011 | 10:42 AM
I changed the sparks plugs last night and helped out alot, but my throtle body sounds like its sucking up to much air should I replace the throtle body or is their a leak around that area?
Old Dec 29, 2011 | 11:32 AM
el crapitan's Avatar
with the engine running, you can spray a little "quick start" in the area. if the idle surges when sprayed, it's leaking
Old Dec 29, 2011 | 11:51 AM
exb18c1's Avatar
Throttle body can not suck more air than it's physical ability,actually throttle body is just a passage and it isn't sucking anything ,it's the movement of the pistons that create a suction.
aavtec
Mar 19, 2013 02:15 PM
gcc1982
Apr 22, 2005 04:05 PM
thejdmkid
Apr 19, 2002 10:51 PM
smkngsr
Jul 2, 2001 09:36 PM
