Exhaust System for B18c
Old Dec 26, 2011 | 01:05 PM
trojan's Avatar
Default Exhaust System for B18c
hi i did a swap to B18c. what do you suggest me to make the diameter of the piping of the exhaust system from the header to the back muffler pls to get some gain?
thanks
Old Dec 26, 2011 | 02:23 PM
Libertariat's Avatar
Ek Forever y0!
Default Re: Exhaust System for B18c
3" is superior on all engines.
The backpressure theory is/was a myth.
You're going to be paying for it in decibels though. You'll gain power all across the band if you're upgrading from a 2.5" -> a 3.0" for example, but it will be a lot louder for a ~5-10hp gain on a pretty modified engine.
Old Dec 31, 2011 | 12:42 AM
trojan's Avatar
so if i make it 2.5" will be enough? though if i make it 3" i think it will be too loud..
thanks
Old Dec 31, 2011 | 01:16 AM
Wrona's Avatar
my friend has 3 inch piping on a WS2 its not that loud but its louder than a reg ws2
Old Dec 31, 2011 | 05:13 AM
flmzero13's Avatar
3'inch function>form
Old Dec 31, 2011 | 07:00 AM
jollygr33n's Avatar
What are the plans for the car? If you'll be going turbo eventually then go with 3" and re-install your cat to keep the noise down. If no turbo is in the future, the gains from a 3 over a 2.5 or 2.25 are not worth the noise IMO.
Old Dec 31, 2011 | 07:56 AM
Ek Forever y0!
2.5" at a minimum. I was just stating a point-of-fact that 3" is more power across the entire power band on every application.
Old Dec 31, 2011 | 11:01 AM
NotAJDMFanBoy's Avatar
3" is not necessary on an NA b18c unless you're heavily modified. You'd gain top end, but lose bottom end. You need to maintain exhaust velocity or you don't get the scavenging effect and the system becomes a hindrance.
2.5" is good. Yonaka makes a knockoff of the 2.5" WS2 system and it has a straight through muffler yet is fairly quiet, at least with a turbo. I'm considering selling mine to go 3" here probably in the spring.
Old Dec 31, 2011 | 11:37 AM
CdLem1's Avatar
^ i agree...what are your plans? if turbo..go with 3'' and if N/A go with the 2.5"...or if your not concerned with the noise level just get a 3"
Old Jan 2, 2012 | 01:18 PM
trojan's Avatar
thanks for the info guys...no dont think i will make a turbo in the future...at least for now for sure..or i will make it half way then...2.75"..what do u think?
Old Jan 2, 2012 | 02:07 PM
motegicivic's Avatar
I do not think 2.75 is really a standard size, I am sure it is out there.
Do not go 3" even 2.5 is plenty, I would sick with a 2.25".
Do have an aftermarket header?
Old Jan 2, 2012 | 02:10 PM
I am pretty sure the Yonaka inner diameter is 2.25"
Old Jan 2, 2012 | 02:22 PM
JTTeG_X's Avatar
2.5" is ideal if your car will be driven on the street and occasional track/strip. I could see 3" being necessary if you were going for a full build and/or turbo. 2.75" would more than likely have to be custom piped. I'd consider 2.5"
Old Jan 2, 2012 | 05:25 PM
speedjunkie_g35's Avatar
From: Pensacola, FL and every Court House in Louisiana
3"= a pissed off bumble bee sound
I went with the yonaka ws2 with 60mm piping for my GSR swap. I am pleased for what I paid
Old Jan 2, 2012 | 08:53 PM
otvcoupe's Avatar
I got a swap on my 00,civic si, b18c1 boosted bigass turbo, I put on 3" piping but I'm working on the exaush part I want a sound just like a subaru , I want something different than usual Hondas. I been searching YouTube on hondas with subaru exaush but they don't tell much... What do you guys sugest?
Old Jan 2, 2012 | 09:01 PM
Hidenplanvew's Avatar
buy a subi... I have one for sale.. 04 wrx...
Subis sound the way they do because of unequal headers... You can make subis sound normal with equal length headers
Old Jan 2, 2012 | 09:11 PM
otvcoupe's Avatar
Lol its possible to get a.really close sound to a Subaru, any other suggestions besides buying a subi lol...
Old Jan 3, 2012 | 07:09 AM
A scooby is going to be my next car project after I build a bigger garage. Wife hates me having so many cars
Old Jan 3, 2012 | 08:23 AM
otvcoupe's Avatar
Any suggestions? What should I use? Should I just snap a sti muffler?
Old Jan 3, 2012 | 08:53 AM
The only way your going to get the same sound as a subi is pulling a spark plug wire of and run on 3 cylinders or as mentioned un equal sized header tubes. muffler won't help you. If you really want a subi sound you will have to do a subi motor swap or this
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/project-first-world-civic-powered-subaru-2763036/
It is in the engineering of the motor and its components as a whole that make a subi sound like a subi!!!
Old Jan 3, 2012 | 12:04 PM
otvcoupe's Avatar
Wow!!! my respects... Any muffler suggestions I should use to get a different sound. I don't like my car to sound like a bee... Something stronger deeper sound?
Old Jan 3, 2012 | 02:23 PM
comarv's Avatar
keept it at a 3 inch diameter
Old Jan 3, 2012 | 02:36 PM
colorfulej1's Avatar
Im trying to make same decision
Old Jan 3, 2012 | 05:55 PM
otvcoupe's Avatar
I'll keep 3" but what muffler should I use?
Old Jan 3, 2012 | 06:03 PM
jbpnoman's Avatar
Whatever muffler you like the sound of.
