AV6/wagon brake swap - bracket problem resolved
Old Oct 8, 2002 | 05:57 AM
mr2td's Avatar
New User
Default AV6/wagon brake swap - bracket problem resolved
Any of you who have been following my brake swap posts will probably remember that I got the wrong caliper brackets with the remanufactured calipers I got from AutoZone.
Well, I called Morse (the remanufacturer) directly and spoke with one of their engineers. Turns out they realized after my phone call that indeed the bracket they supply is wrong. As of today they are shipping me a set of correct brackets! (the 25T, I assume.) Apparently they are doing an investigation into this problem at their facility.
Makes me feel good to see that I was able to help them straighten out this problem. Kind of hard to believe that I was the only one that had this problem - or was I the only one that complained??
I should get the new brackets this weekend - hopefully they're the right ones
Old Oct 8, 2002 | 09:04 AM
exvtec94's Avatar
Default Re: AV6/wagon brake swap - bracket problem resolved (mr2td)
do you have the part #'s for the two calipers??
Old Oct 8, 2002 | 09:12 AM
greensleeper's Avatar
job well done.
Old Oct 8, 2002 | 10:04 AM
typer_801's Avatar
Hmmm....I recently bought remanufactured AV6/Wagon reman caliper from PepBoys and they did *not* include brackets, so I went out and bought them seperately from a junkyard. I spent more total $'s by buying the calipers ($39.99 each) and brackets than if I had bought them together at AutoZone. Oh well!!!
Old Oct 9, 2002 | 09:52 AM
mr2td's Avatar
New User
Default Re: AV6/wagon brake swap - bracket problem resolved (exvtec94)
The pair of loaded calipers was $87.99 + core charge. They were Morse part number P1460.
Hope to get the brackets installed this weekend... I'll let you know how it turns out.
Old Oct 9, 2002 | 09:53 AM
mr2td's Avatar
New User
Default Re: AV6/wagon brake swap - bracket problem resolved (typer_801)
Yeah, typically they don't come with the brackets. The loaded ones come with the brackets, all of the hardware (sliding pins, etc.) and new pads.
Integra4lyfe069
May 10, 2011 07:36 PM
endlesswinterco
Suspension & Brakes
May 15, 2008 07:13 AM
cam0693
Mar 30, 2003 08:44 PM
gohandbz8
Mar 29, 2003 05:46 PM
