hole through exhaust manifold stud port
Old Dec 26, 2011 | 10:07 AM
boostfever's Avatar
Default hole through exhaust manifold stud port
Took my gsr head to a local shop to remove a stripped exhaust stud out and notice today that there is a hole where the shop took my stud out. I can see pretty much the inside of my head. Talk with the shop and they said that the hole was already there. Is there anyway I can weld the hole and re tap it? Any ideas? Will this do any damage to my motor? Thanks
Old Dec 26, 2011 | 10:11 AM
boostfever's Avatar
Default Re: hole through exhaust manifold stud port
Engine oil is coming out of the opening. It's the exhaust stud port by the passenger side.
Old Dec 26, 2011 | 12:47 PM
komat's Avatar
umm thats not normal. did they drill in too deep? you could try putting a stud in and see if it seals it
Old Dec 26, 2011 | 01:00 PM
rich7777's Avatar
Pictures please...
Old Dec 26, 2011 | 02:09 PM
Root of all Evil's Avatar
This happens way too much, who worked on it at the machine shop? Probably a first year apprentice. Make them fix it! It was not there already that's retarded.
Old Dec 26, 2011 | 04:02 PM
boostfever's Avatar
Yes they must of drilled the hole to deep to where I can see right through the head. I'll take a picture ignite once I take off my turbo manifold. I just inserted a bolt in the stud port for now and it still leak but not as much. The hole is pretty ****ed up to where I can see the block surface. Is there some kind of oil port on the passenger cylinder head? will this be the problem my engine is idling rough do to lack of compression? Should I just weld the hole and re tap it?
The machinist at the shop said that the hole was already there and nothing he can do about items told me I should be glad the stud was out.
Old Dec 26, 2011 | 07:33 PM
Phan.wayne's Avatar
Is it a used head? Sounds like the machine shop f'd up unless you bought one with hidden problems.
Old Dec 27, 2011 | 03:06 AM
IN VTEC's Avatar
If the oil isn't a feed passage, you may want to try Hondabonding the threads.
Old Dec 27, 2011 | 03:15 AM
RickyLee53's Avatar
I wouldn't worry about it, just use some good sealant around the threads.
The standard Mitsi Evo's have all the bottom studs onto the exhaust manifold through an oil gallery.
Old Dec 27, 2011 | 06:41 AM
nealnanoHX's Avatar
I would have the shop fix it, it is there f^&k up anyways and they just are not owning up to it. I had a head destroyed by a machine shop, it was a real nightmare to deal with them.
Old Dec 27, 2011 | 10:47 AM
boostfever's Avatar
going to have a buddy weld the hole and see how it goes from there. thanks for the input guys.
Old Jan 3, 2012 | 08:19 PM
B and B's Avatar
Loved
Community Favorite
one of my sigs in rotation
Originally Posted by IN VTEC
I swear to God machine shops are the weakest link in any engine build.
invader_zim
Jan 24, 2013 09:19 PM
boostfever
Dec 26, 2011 09:15 PM
96f22b2
Jun 4, 2009 08:11 PM
LudeToAHatch
Jan 6, 2006 08:09 AM
rocketfuelcerx
Aug 22, 2005 02:31 PM
