Ideas about how to go from rectangular head port to round manifold runner
What would be the best way to transition from a rounded rectangular exhaust port (SR20DET) on the manifold flange to a round runner tube? This isn't normally a problem for people using 1-1/2" runners but I want to use 1-1/4". The perimeter of the exhaust port is ~4.9" and the perimeter of the outside of the 1-1/4" runner is 5.2 but the mild SCH40 is so thick.
Should I shape the runner into an oval shape to better align? cold or hot?
Should I purchase concentric transitions?
Should I fab a transition by chopping up some pieces of pipe?
Just weld it and blend the transition with a grinder?
Any other ideas?
Thx,
Mike
Any other ideas?
Thx,
Mike
With an anvil and 5 lb sledge it ovaled a lot easier than i had imagined. I guess I'll just shape it the best I can, weld and blend.
Oval and Blend will do the job pretty well !
I have done several manifold that way, same thing for the collector.
Sch 40 is thick, but if you use a carbide bit, be carefull not to remove to much material in the tube, instead, make a nice thick weld around the tube and head flange, it will give you a strong joint even if grinded.
good luck !
good luck !
No joke, those flanges are nice. It looks to be the same company as SLS. I get my flanges from them, price is identical, fast shipping.
RO_SUNNY
Welding / Fabrication
Jul 19, 2011 12:55 PM
