hatchback cx power window conversion
Old Dec 26, 2011 | 12:13 AM
oh_dam's Avatar
Default hatchback cx power window conversion
is it possible for me to convert to power windows and lock with a 2000 civic floor harness and doorharness ? my car is a 97 hatchback cx
Old Dec 26, 2011 | 01:02 AM
NOFX's Avatar
H-T White Ops
Default Re: hatchback cx power window conversion
The plugs changed in 1999.
So if you want to do a power door conversion you're going to need the parts from your year range.
The year ranges are:
1996-1998
1999-2000
The plugs are different for those groups, so you must stick to the matching years.
There should be plenty of DIYs to do the conversion, but it's basically just removing parts, adding parts and time.
IIRC (research yourself, please; I'm not sure this is all correct):
REMOVE
Front seats
Center console pieces
Lower door jamb trim on at least one side (forget if it's attached to the carpet for these years)
Carpet
Driver knee bolster panel
Under dash fuse box
Non-power door cards
REPLACE/ADD
Floor harness
Door harnesses
Power door cards
That should be about it. I did this project with someone else in a 1997 CX hatch. We used parts from a 1998 EX coupe. It probably took us something like 5-6 hours I think. It was mostly time consuming beyond anything else. It wasn't hard.
Old Dec 26, 2011 | 04:14 AM
oh_dam's Avatar
Thanks i've been doing a lot of researching and reading about if it's possible. because i have a complete 00 si floor harness and doors . i was wondering if it would be possible to just convert the si main connectors to the cx connector.
Old Dec 26, 2011 | 01:56 PM
confidence's Avatar
The best solution is to sell you wiring and use the $ get the 96-98 wiring. I have first hand experience trying to convince 96-98 wiring to work with 99 wiring and it's not fun. the 99 has few less or a few more wires than the 96-98, i can't remember which.
The lock curators and window motors are the same for all years so keep those if you already have them
Old Dec 26, 2011 | 10:44 PM
oh_dam's Avatar
I appreciate for the help guys ! but i actually spent all day today and i just converting the 99-00 harness to work for ther 96-98 . everything works perfectly (:
99_<ivi>_SI
Nov 14, 2012 05:01 PM
egflip
Jun 7, 2010 12:45 AM
jason_v2
21
Mar 12, 2009 03:21 PM
rayzhatch95
Mar 20, 2004 10:17 PM
