ac and cooling fan not working
Old Dec 25, 2011 | 11:45 PM
chatosf415's Avatar
Icon6 ac and cooling fan not working
I have a 93 accord and both ac and cooling fans are not turning on I have put direct power to each fan and they turn on with no problem I have swaped out the relays with good one changed the fusesand still nothing what more can I do any help from you folks would be great thank
Old Dec 26, 2011 | 03:37 AM
PT-Tuner.com's Avatar
Default Re: ac and cooling fan not working
What about the temperature senders?
Old Dec 26, 2011 | 04:58 AM
Nonio's Avatar
Geez ... there seems to be an epidemic on faulty cooling fans.
https://honda-tech.com/forums/showpo...6&postcount=13
http://www.megaupload.com/?d=S89SCDVF
Hope that helps.
Old Dec 26, 2011 | 05:07 AM
poorman212's Avatar
Key on, remove the wires/connector from thermo a (green connector by t-stat), use a paper clip or something and jump the two wires together....do BOTH fans come on?
Old Dec 26, 2011 | 04:45 PM
559wagovan's Avatar
im having the same issues too with my cooling fan. at first it was the green wire to the temp gauge sensor that broke off and i just fixed that problem and the gauge is now working fine. and then i just replace the coolant temp switch next to that one. but the fan isnt turning on and the engine temp just sky rockets. is there something else i should check.
everything was working perfectly fine until the wire broke on the coolant temp gauge.
i would appreciate any help.
Old Dec 27, 2011 | 07:24 AM
Lost Again's Avatar
Not sure if you replaced the correct switch?
Anyway, have you ruled out a bad t-stat, your comment about the temp "sky rockets" makes me ask this.
Then, thermo a (green connector by the t-stat-lower hose) controls the fan operation when the car is on...not close to the single wire temp sending unit on the end of the head.
Old Oct 7, 2013 | 12:26 AM
chatosf415's Avatar
ok this is what I have done to the car new radiator new fan switch sensor new temp sensor new cooling fan sensor so all the sensor are new and so is the thermostat new relays so WTF is going on dang it
Old Oct 7, 2013 | 09:07 PM
holmesnmanny's Avatar
assuming you have installed all correct parts in the correct location the only thing you haven't changed out is the fan control unit
angrysmileyface
May 12, 2018 11:24 AM
duyfash0
Oct 8, 2008 06:46 PM
Panda hatch
Jun 15, 2006 09:43 PM
omgwtfbbqcrx
Apr 21, 2006 12:19 PM
