92 Accord COMPLETE wiring diagram????
I have a wiring problem in the steering column.
6 pin connector under dash goes to the key light and key light switch.
I am trying to identify where the other wires in that connector go as well as the wiring for the small solenoid located on the side of the ignition switch.
If I only had a real wiring diagram for this car I could trace this stuff out.
Any help would be appreciated!! If I knew what these items did or what there called, what systems they worked with I could narrow down where to look in the service manual.
I know the wht/ylw from the 6p connector is 12V from the underhood fuse box fuse #25 stop/horn 20A
wht/blu ??
wht/red ??
solenoid on ign switch
wht/red ??
blk/red ??
switch on bottom of ignition switch (small arm extends into ignition switch senses key rotation) has to wht/ylw wires coming out of it
wht/ylw ??
wht/ylw ??
Im confident that switch and solenoid have something to do with the wires in question but it seems there is something still missing.
I just got the car and it is a theft recovery and I already repaired the ignition harness and got it running, just trying to get the wiring all buttoned up.
Please any help or a direction to go for a solution
wht/blu ??
wht/red ??
wht/red ??
blk/red ??
wht/ylw ??
wht/ylw ??
Hi,
Look for it in here :
http://www.megaupload.com/?d=S89SCDVF
I'm sure it's gotta be in there somewhere.
JokerX-1.6T
May 2, 2008 05:06 PM
