anyone with a picture of a 1.5L oil pan???
Old Dec 25, 2011 | 09:51 AM
lochenjons's Avatar
Default anyone with a picture of a 1.5L oil pan???
Hey guys, I'm fairly new to the honda world, and am just curious to see what other people's oil pans look like. it looks like to me that I have a large dent in the front of mine. It started to leak a lot of oil from what I'm guessing is the gasket? (I hope because it's an easy fix) and I went to investigate and saw it. A couple of weeks ago I hit a pretty bad pothole on a dirt road which caused the skidplate to break, I'm thinking that's what might have caused it.
here's a picture. There was a lot of oil dripping from the driver's side of the oil pan where the pulleys are, not sure if it's cause it's parked on a slight slant, but there's a lot of oil all around the bolts that hold the pan on. If it is dented, but not cracked, is it a good idea to reuse the pan?
Old Dec 25, 2011 | 10:22 AM
miguey310's Avatar
Default Re: anyone with a picture of a 1.5L oil pan???
picture isn't working
Old Dec 25, 2011 | 10:29 AM
acmoc's Avatar
oil pans are fairly cheap. I advise you get a new one
Old Dec 26, 2011 | 12:09 AM
Exelbaradin's Avatar
agreed ^^^
Old Dec 26, 2011 | 01:31 AM
NOFX's Avatar
H-T White Ops
Use a site like imgur.com to host your photo and then paste the URL in this thread.
I'm betting you have a damaged oil pan. I pulled the D15 out of my CRX and it didn't look dented on the bottom. It was almost flat, actually.
Old Dec 26, 2011 | 06:08 AM
lochenjons's Avatar
Yeah I uploaded a pic on imageshack but forgot to attatch it haha... I uploaded a pic on my phone, hopefully this works
Old Dec 26, 2011 | 12:00 PM
miguey310's Avatar
i doubt it's the dent just replace the gasket but to be sure clean it up real good and turn on the car and wait til' you where the leak is coming from
Old Dec 27, 2011 | 09:29 AM
lochenjons's Avatar
but it is dented right? i know some oil pans have weird shapes i just want to double check. i dont really want to go get another oil pan but if i have to i will
Old Dec 27, 2011 | 10:33 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
What are you talking about? That dent is clear as day and you can even see where the oil pan is buckled.
OP - just do yourself a favor and get a OEM oil pan gasket and source a new or used oil pan. (The reason for OEM Gasket is most of the aftermarket ones don't have the grommets in them so when you try to torque the down they either split or leak anyways.)
Old Dec 27, 2011 | 10:41 AM
miguey310's Avatar
my old oil pan had a dent like that and it never leaked! and notice all the oil is near the gasket and not where it's buckled.
op- just get a new oil pan while your at it.
Old Dec 27, 2011 | 04:42 PM
lochenjons's Avatar
ok i got the new oil pan gasket, and some permatex black to put on it when i install it... will go to pick n pull tomorrow and grab a new one.. cheap insurance
Old Dec 27, 2011 | 04:45 PM
acmoc's Avatar
I have one for sale
Old Dec 27, 2011 | 05:02 PM
lochenjons's Avatar
how much
Old Dec 27, 2011 | 05:03 PM
DO IT ON ALL FOURS
Do NOT use any type of gasket maker substance. This DEFEATS the purpose of the oil pan and gasket design...
Old Dec 27, 2011 | 05:42 PM
acmoc's Avatar
Sorry, I actually am going to use it, same situation you're in
Didn't know I didn't need gasket maker thanks
acmoc's Avatar
They're on ebay for 50.00 bucks new
muscleman0745
Jun 3, 2010 05:05 AM
hondaboy4life
Sep 29, 2006 08:01 AM
uEDarkShadow
Jul 13, 2006 07:02 PM
LAKER HATER
May 21, 2004 07:51 AM
shming123
Apr 16, 2003 11:12 AM
