OBD1 b18b1 head on an OBD2 block?
Old Dec 24, 2011 | 01:19 PM
LSteggyguy's Avatar
Default OBD1 b18b1 head on an OBD2 block?
can i run this?
if i use my OBD2 dizzy, Valve cover and intake mani would it work?
are the OBD1 and OBD2 heads the same other than the dizzy/IM/VC?
Old Dec 24, 2011 | 04:46 PM
Wrona's Avatar
Default Re: OBD1 b18b1 head on an OBD2 block?
pretty sure you can i dont see why not
as long as you swap out all the components like intake mani dizzy you'll be good
the dizzy on a OBD1 has 2 plugs thats y its diffrent
the Intake manifold has some diffrent sensors on it i think
the valvecover all fits i have a B20 valvecover on my LS
Old Dec 24, 2011 | 11:37 PM
mouab18c1's Avatar
Yes it will work.
Old Dec 24, 2019 | 02:17 AM
Eclipse904's Avatar
i have a obd2 head and it has apcv on the valve cover? And i just got an obd1 block b18b1 it has a black box . so what do i do or how would i run the pcv system?
Old Dec 24, 2019 | 06:08 AM
aw614's Avatar
10 Year Member
Loved
I think you have several options.
Run an obd1 valve cover and run the blackbox components.
Or run the obd2 valve cover and PCV valve, but then block off the blackbox and vent only the head, similar to what some people do with B series VTEC block and heads, but you'll run the pcv on the valve cover to the intake manifold.
There may be more options, but some that I just thought.
Old Dec 24, 2019 | 12:47 PM
jdmark1's Avatar
Both great options. Personally, I'd go with the first. If you don't want to find a OBD1 valve cover, but you plan to stick with the black box system on the OBD1 block like the fist option says, you should be able to just put a vacuum cap on the PCV valve on the valve cover. That would block it off.
Nos651
Jan 12, 2015 02:54 PM
osbunjosh
Mar 26, 2012 06:39 PM
BoogiepopJDM
Jun 16, 2007 02:51 PM
1991hb
May 12, 2007 12:34 AM
