DC2 Camber kit question...
The only reason for the camber kit would be to make your camber specific. That means old school alignment, not laser.
Let me make it clear. "Tolerances won't be tolerated, either it is right or it is wrong, not almost."
sorry no pix for right now. but the car is pretty low. i do not like the stance of the front wheels because they lean inward. what do i have to get in order to be slammed and fix this problem?
It's not a problem. It's normal, it happens when lowering the car. Unless your runing some stupid amount of negative camber IMO it really dosn't look that bad. But, maybe I am just used to seeing my car.
The ONLY way to fix this in front is a camber kit. Which poses it's own issues if the car is too low...
You don't want the front wheels to be "straight."
Some camber is a good thing.
Did he tell you what your camber is? Most places will check your alignment for free.
no but ive seen it. its on the top inside. its hard to explain. but i definetley think i need an alignmebt as well. btw how can some camber be good?
0 camber is bad. Only useful at the drag strip. Even then .3-.5* of camber is good for stability and safety.
Seen what?
If your tires are wearing unevenly it's more probable that it's the toe or caster wearing your tires. Camber does wear tires more quickly on the inside, but many users on these forums (myself included) have ridden on 3-4* camber for years with even tire wear.
Caster doesn't wear tires either, it just causes pull and other handling issues.
OP, get rid of the cut springs and then get an alignment. There's a good chance your camber will be okay and having the toe set will be all you need.
Your car came from the factory with 1* of camber. It makes the car handle better and is thus safer.
Seen what?
Seen what?
kraaaaap
20
Jul 6, 2007 09:14 AM
madcrossover
Oct 19, 2004 10:05 AM
