zc swap is killing me
Old Dec 23, 2011 | 10:15 AM
BigbamaBen's Avatar
Default zc swap is killing me
OK I still have the harness issue. However I found a complete 89 harness. If I were to put the harness into the 88 other than the fuel pump would everything else work
Old Dec 23, 2011 | 11:16 AM
90civic-ZC's Avatar
Default Re: zc swap is killing me
Well what problems are you having? I have no clue to your situation.....
Old Dec 23, 2011 | 11:25 AM
stackedhouse's Avatar
Yes it will work perfect and run forever
Old Dec 23, 2011 | 11:30 AM
BigbamaBen's Avatar
Well the previous owner of this 88 Crx had issues with the car (gas needle was off and was out of fuel). In his infinite knowledge he figured it was wiring and tore the entire harness out of it and rewired the car himself. So now I'm trying to put a Honda harness back in there instead of the hillbilly deluxe wiring in it now
Old Dec 23, 2011 | 11:37 AM
90civic-ZC's Avatar
hahaha! nice! I hate that man.....yeah it'll work like the other guy said, as long as you're still DPFI and your CRX isn't a SI. Unless you're doing the MPFI yourself....I'm not sure what engine you're using but I think you catch my drift. Good luck with the new harness.
Old Dec 23, 2011 | 08:38 PM
BigbamaBen's Avatar
So basically stick with the same sub model? What would happen or what would I need to change to cross that magical barrier and put a 91 harness in it
Old Dec 23, 2011 | 08:51 PM
90civic-ZC's Avatar
You can put any harness in it, just depends on what you're trying to do with what you have....What engine do you have? Are you staying DPFI or going MPFI?
Old Dec 23, 2011 | 09:24 PM
BigbamaBen's Avatar
I'm doing a zc swap so it has to be an si harness. I'm trying to figure out what else I'd have to change other than the fuel pump if I were to put a 91 si harness in it
Old Dec 24, 2011 | 07:44 AM
90civic-ZC's Avatar
You don't "have" to put a SI harness in it. You can keep your harness but there would be some wire work. I have my original DX harness, I just had to mod it a bit for my ZC swap. And which ZC single or Dual? What OBD are you going to run? The DOHC ZC has a CPS on the exhaust cam, but if you're going OBD1 you don't have to worry about that. There's a guy you should talk to on here, he custom makes harness's for people.
Old Dec 24, 2011 | 08:06 AM
JDpower's Avatar
Im running an HF harness (cabin/engine) with my zc.
Old Dec 24, 2011 | 08:13 AM
90civic-ZC's Avatar
I forgot about you're redneck chop job you said when you bought it. But you don't have to use a SI harness.....since you're not going to be using your original harness I would seek out that guy on here that custom makes harnesses so it's just plug and play for you.
Old Dec 24, 2011 | 02:23 PM
BigbamaBen's Avatar
Its the 1.6 dohc zc. Well I already have an si. And I have a 91 si harness. I'm running obd0 and I bought the distributor adapter. What is the CPA?
Old Dec 24, 2011 | 03:39 PM
90civic-ZC's Avatar
I told you, it's the number 1 cylinder position sensor that goes on the exhaust cam.
Old Dec 24, 2011 | 04:22 PM
BigbamaBen's Avatar
So will the car not run if I don't connect it or is there any other wiring fixes I can do
Old Dec 24, 2011 | 05:12 PM
crx_si-r's Avatar
Ok, fuel pump does not need to be changed out. If you dot wire in the separate ckp sensor
On the exhaust cam then your car will not run. Aside from this if you have a DPFI set up, you will need to perform the standard mpfi conversion.
Make it simple and start over since the previous owner already messed up the wiring. Feel free to txt me 916-541-5266
Old Dec 24, 2011 | 09:28 PM
90civic-ZC's Avatar
^ there he is.......No offense man, but it sounds like this job may be easier for you if you just get him to make a harness for you. I promise it'll make you're life 100% better with less headaches and you'll have more time to work on other things.
Old Dec 24, 2011 | 09:36 PM
crx_si-r's Avatar
I just saw what I wrote earlier. Stupid IPhone. Lol
Old Dec 24, 2011 | 09:40 PM
90civic-ZC's Avatar
Haha, Are you speaking of the word "dot" you used?
Old Dec 25, 2011 | 05:35 AM
crx_si-r's Avatar
That and the abrupt ending of sentences
Old Dec 25, 2011 | 07:53 AM
90civic-ZC's Avatar
hahaha! you're good man, atleast it's not like the guy with the post for "crazy ignition timing". Just for OP's sake, if he would send you his SI harness he bought would you being to set him up for a plug n' play set up? I ask because I'm a bit curious too about something like that, and do you do B series too?
Old Dec 25, 2011 | 09:24 AM
crx_si-r's Avatar
Yea I'm gonna build him a brand new harness when I get his core. I do d, b, h and f harnesses
Old Dec 25, 2011 | 10:42 AM
90civic-ZC's Avatar
Nice! that's what's up.
Old Dec 25, 2011 | 03:21 PM
BigbamaBen's Avatar
Oh trust me I know. I think I also scared myself. I was gonna go change the spark plugs on the zc to get it all ready and what not. There's antifreeze in the spark plug wells. Anyone see a.problem with this
Old Jun 20, 2019 | 06:55 PM
Alex Mendez's Avatar
What changes do I need to make on a si/hf harness to run b series?
ShadowKhaN
16
May 3, 2016 11:12 AM
FloMotion
May 26, 2013 07:41 PM
h22 kamikazi
Jun 12, 2007 04:45 PM
jonsimo
Mar 24, 2004 11:27 AM
