eg LS swap help
Old Dec 22, 2011 | 06:19 PM
eg93bubble's Avatar
Default eg LS swap help
hey honda tech need a little help. Im new to the honda scene since im more of a muscle car builder but decided to see if i can have fun with a honda. ok so i bought a 93 eg bubble shell that i want to put an ls motor in. my friend just totaled his 97 integra and he was gunna give me the things i need to do the swap but the problem i think id be facing is that the integra is an obd2 and the bubble is obd1 so would i still be able to use the motor and trans and just get a different harness? just need a list of the **** ill need and what other parts would be able to swap over likes brakes, interior? thanks for the help
Old Dec 22, 2011 | 06:34 PM
eg93bubble's Avatar
Default Re: eg LS swap help
bump
Old Dec 22, 2011 | 06:45 PM
Wrona's Avatar
http://www.hondatech.com.au/forum/showthread.php?t=771
Old Dec 22, 2011 | 07:18 PM
colorfulej1's Avatar
All u gon Need is obd1 distrubutor alternator injectors nd eryting else is fine
Old Dec 23, 2011 | 01:25 AM
HondaPartsHero's Avatar
Technical Hero
If you get his engine wiring harness that connects to the shock tower on the passenger side it'll be plug and play. You don't need the OBD1 distributor, alternator and injectors. You will want to get an OBD1 92-95 LS P74/75 ECU however. You don't want to use an OBD2 ECU.
Old Dec 23, 2011 | 01:27 AM
Technical Hero
Check the FAQ above it'll tell you all you need to know about the brakes, interior etc that swap over.
Old Dec 23, 2011 | 03:03 PM
eg93bubble's Avatar
ok cool thanks guys appreciate the help
eghatch03
May 25, 2016 03:44 AM
jthrasher1
Nov 19, 2010 06:41 PM
eggsi619
May 4, 2009 03:12 PM
96electronH
Sep 18, 2008 03:46 PM
TURBOED-TEG
Sep 17, 2002 05:05 AM
