skunk2 pro 3's question
Old Dec 22, 2011 | 02:45 PM
boostontheD's Avatar
Default skunk2 pro 3's question
i have a question about getting a set up pro 3's
i am building a sleeved gsr motor.
goal for whp is 800+whp
most likely going to use a stock port head with all valvetain upgraded.
will the pro 3's be to much for the power that im wanting to make?
the block will be a benson sleeved block with corrilo rods and weisco pistons probably going 10:1 compression.
any info would be great. this is my first B series build and wanting to go for a lot of power.
built a few d series last one made 475whp on stock sleeve vitara setup.
Old Dec 22, 2011 | 02:52 PM
cibao2ner's Avatar
Default Re: skunk2 pro 3's question
pro1s for boost....
Old Dec 22, 2011 | 07:40 PM
Originally Posted by cibao2ner
pro1s for boost....
thanks man.
thats what my tuner said too! said that the pro 3's have to much over lap.
Old Dec 23, 2011 | 02:56 PM
ls_on_boost's Avatar
same here im going for 850+ power with another motor and my tuner also told me pro1s
Old Dec 23, 2011 | 03:00 PM
sounds like we have similar goals!
mine will be a GSR benson sleeve 10:1 compression.
stock port head with pro 1's now and buddy club valves
buddy club retainers victor x manifold
top mount with most likely a 6765.
on 120 oct
Old Dec 23, 2011 | 03:23 PM
cibao2ner's Avatar
pro3s are too big for boost...pro1s are proven to make power....tony1 broke into the 8s using pro1s so you wont need more than that...
btw i have a fully built jdm itr rlz ported head with ferrea roller rockers and crane cams in the forsale forum..
not for a street car but 800whp isnt streetable anyways....
btw i would go with ferrea valves for boost....best valves on the market..
Old Dec 23, 2011 | 05:53 PM
SPOOLINmatt's Avatar
i bet they will still make just as much power and prolly just as effectively.
Old Dec 23, 2011 | 07:40 PM
couldnt find your head for sale
are you talking about the valves?
Old Dec 23, 2011 | 07:46 PM
also which ferrea valves would you prefer?
5000 flat valves? thats just the first valves i found on a quick ebay search
Old Dec 23, 2011 | 07:54 PM
cibao2ner's Avatar
i have competition plus on that head....but the 6000 will do fine...
Old Dec 23, 2011 | 08:18 PM
what is the standard size on a gsr head?
are they
28mm exhaust
33 mm intake?
Old Dec 23, 2011 | 08:23 PM
also will the SK2 tuner dual valve springs do the job i need? or should i go with the pro series?
or a different brand?
i always ran supertech with my D16.
Old Dec 23, 2011 | 08:47 PM
cibao2ner's Avatar
supertechs are fine...and yea 33mm 28mm are std
Old Dec 23, 2011 | 09:24 PM
V-SPEC 1's Avatar
Will the valves hit if you were going 1mm oversized on the intake and exhaust running pro1?
Old Dec 24, 2011 | 04:36 AM
no im talking about the cams.
Old Dec 24, 2011 | 06:32 AM
00Red_SiR's Avatar
All Motor Mentor
If you don't check your V2V clearences and your safe cam gear adjustability range before you hit the dyno and try to tune them, yes.
Old Dec 24, 2011 | 05:10 PM
Tony the Tiger's Avatar
Pro3's are ridiculous for boost... All that cam and creating all that abuse on the valvetrain for really no good reasons either.
Anything past Pro1's, you end up closing up all the overlap, unless your engine is insanely built to use up all that duration.
Meaning, if you have a 4" open downpipe, a T6 frame 80mm+ turbo (the bigger the merrier), some sort of straight-shot exhaust manifold, 11.0:1+ CR, and you plan to make 800 WHP at under 20 PSI of boost before exhaust pressures become an issue...LOL
Deej23
K Series
Feb 17, 2014 05:32 AM
AllmotorK24/k20
Mar 12, 2009 03:41 AM
2fast4jdm
Dec 3, 2008 03:59 PM
del_orson
Aug 4, 2007 03:27 PM
VtecKiDD
27
Oct 24, 2005 06:00 PM
