B20 into EK, Motor sits funny.
Old Dec 22, 2011 | 10:16 AM
oXeNo's Avatar
Default B20 into EK, Motor sits funny.
I just finished putting a b20 into my EK Coupe, I used the timing belt mount that came on the motor I have 99-00 Si bracket as well but I didn't use it. But I put the motor in and everything lined up and I finished bolting everything together. But when you look at the motor you can tell the timing belt side of the block sits quite a bit lower then the rest of the motor. I can't figure out what is causing it to do this, is it cause I used the CRV timing belt bracket or what?
Old Dec 22, 2011 | 11:48 AM
EsotericImage's Avatar
Retired Moderator
Default Re: B20 into EK, Motor sits funny.
yup!
use the Si bracket!
lolz @ EK coupe
Old Dec 22, 2011 | 12:00 PM
oXeNo's Avatar
Alright cool thanks, I was just in a hurry to type this I know I didn't use the correct chassis code and **** for the car lol I just wanted to try and get an answer as fast as I could so I could fix it.
Old Dec 22, 2011 | 01:37 PM
BryanM.'s Avatar
Resident Gearhead
Originally Posted by EsotericImage
lolz @ EK coupe
Look, 99% of the cars called EKs on here aren't EKs. Telling people that only pisses them off and never teaches them anything though. It never sticks. They'll keep calling them EKs so your battle isn't even an uphill one, it's a useless one.
Had to be done.
Old Dec 22, 2011 | 02:35 PM
94EG8's Avatar
Seagull Management
The Si and the CR-V use identical brackets.
Old Dec 22, 2011 | 02:46 PM
Wrona's Avatar
yeah because the crv is a bigger civic atleast 1st gen is
Old Dec 22, 2011 | 03:06 PM
94EG8's Avatar
Seagull Management
Also, just as a side note you can use the fluid filled mount from a CR-V in a '96 - '00 Civic as well, I think it's stronger, it has a different part number, but it fits the same. I have personally done it before and it works, CR-V engine harness also works in a '96 - '00 Civic ('97 - '98 harness for '96 - '98 Civic, '99 - '01 harness for '99 - '00 Civic)
Old Dec 22, 2011 | 04:15 PM
Retired Moderator
I did not know that.. i just tossed mine in the trash with the giraffe intake,flex plate, and everything else useless on a B20
learn something new all the time on this board.
Old Dec 22, 2011 | 05:52 PM
maznkid's Avatar
How much of a power increase was it from the D series? Im thinking about swapping my d16y8 for a B20B
Old Dec 22, 2011 | 06:32 PM
Wrona's Avatar
reaserch is nice no
dck1ng69
Mar 14, 2017 09:33 PM
killahatch
13
May 27, 2009 05:58 PM
Damills
Feb 25, 2009 09:47 AM
shake-zula
Aug 12, 2008 08:02 AM
ef ect
Nov 5, 2002 09:28 PM
