both low beam headlights not working
2007 honda accord lx
high beams work but low beams do not work. checked the fuses and both have power. what do i need to check from here? Tail lights and blinkers work
i was hoping to find someone that who knew how to diagnose the problem before just dropping money on new bulbs that could not be the problem. i just find it a little too coincidental for both headlight bulbs to go out at the same exact time.
Could be a coincidence ive had it happen my other car. **** happens plus it gives you a reason to buy better bulbs. Did you also check further than the fuses? Such as the connections where the bulbs are.
