Anyone got a GT3251B map?
Ask, and you shall receive. However, the housings used in the application you're looking at are changed relative to this map that doesn't reflect the .63A/R and 2.559" turbine wheel. This is strictly the compressor map.
So, i plotted the map, and i think this is too big for b18b?
I used the following numbers to plot the line... granted, this isn't strictly gt3251 map, but how far off of this gt32 vs gt3251? I don't think i should push it to 10psi either with a bone stock b18b?
Could someone tell me how will the 51mm vs the 71mm be different on the compressor map? Will the 51mm effectively shift the whole graph to the left side, making it a better match for the b18b? By the look of it now, it would only hit full boost making ~250whp at 6800 rpm right?
