2001 Prelude Cold Start Issues
Old Dec 21, 2011 | 03:40 PM
Flipking's Avatar
Default 2001 Prelude Cold Start Issues
All started after I did a compression test. Car ran fine before this. I did not(should have) take out the fuse to the fuel pump, so fuel was entering the cylinders during test. Numbers came out good at 225, 215, 215, 225. After the test, the car is having trouble starting when cold. When i eventually get it started, it runs rough for about 3 mins and then runs fine. Before test, I had a CEL for the o2 sensor, was on for a few months. Since the car has had trouble, I have replaced the spark plugs, and the o2 sensor. The car is throwing 6 misfire CEL's. No oil in coolant or vise-versa. Really at a loss. Any help? My next guess is maybe the fuel injectors?
Old Dec 21, 2011 | 06:40 PM
vinuneuro's Avatar
Default Re: 2001 Prelude Cold Start Issues
Test the coil according to the helms. If you didn't pull the coil plug before the test, it's likely gone. I've done the same before in a hurry. Charge builds up with no where to go.
Old Dec 21, 2011 | 07:00 PM
Flipking's Avatar
Can do, I'll check that tomorrow. Also, when cold, if I take the radiator cap off, it seems to spit coolant out. Its possible its because the motor is surging and sputtering but I am thinking it might be air. Gonna do a cold compression test and a block test tomorrow also to check my headgasket.
Old Dec 22, 2011 | 04:27 PM
Flipking's Avatar
Cleaned the egr valve and seem to have fixed my issues. Thanks for the advice though
Old Dec 24, 2011 | 03:58 PM
Flipking's Avatar
Well started back up. Now thinking that it is the ignition control module in the dizzy.
Old Dec 26, 2011 | 11:56 AM
exb18c1's Avatar
ignition coil would do the trouble even after the motor is hot.
Old Dec 26, 2011 | 10:27 PM
holmesnmanny's Avatar
In addition to disabling the fuel pump you gotta disable the ignition as well. This can be done by pulling the ECU fuse. You probably either burned out the coil or the igniter. I would test them both cold and hot.
I did the same exact thing myself. Take off the cap and see if there's a white smoke film on the inside of the cap.
Old Dec 26, 2011 | 10:40 PM
hondawhiz's Avatar
One guy had a similar problem and it was his vtec solenoid that was stuck open
Old Dec 27, 2011 | 02:57 PM
Flipking's Avatar
Well I replaced the ignition control module and that didn't fix the issue. Have now replaced the spark plugs, 02 sensor, igntion control module. Gonna test coil next I guess. So very frustrated. What really gets me is how well it runs once it starts and runs rough for about 2 mins. Once it starts to run right....it runs perfect.
Old Dec 27, 2011 | 10:42 PM
hondawhiz's Avatar
Check your temp sensor and its wiring this is a probable cause trust
Old Dec 27, 2011 | 11:38 PM
ya, this could be coolant temp sensor below the distributor. Like 20 bucks from autozone.
Old Dec 28, 2011 | 08:59 AM
Flipking's Avatar
Wouldn't my temp gauge be doing wierd things if that were bad?
Old Dec 28, 2011 | 09:00 AM
Flipking's Avatar
and Its not the coil, Tried that today. lol
Old Dec 28, 2011 | 11:29 AM
That's a different sensor, the one that sends the temp to the gauge on the cluster is the temperature "sender" which is the smaller plug, we're referring to the coolant temperature "sensor" which is the larger plug of the two. They are right next to each other under the distributor.
Old Dec 28, 2011 | 11:56 AM
Flipking's Avatar
well, I talked to a Honda Tech. He said to try a dif test. He said get the motor started and warmed up. Then take out the spark plugs and hold a mirror over the spark plug hole. If the mirror fogs up, then its a head gasket. Cylinder 3 fogged up. Its getting harder and harder to start and now running like crap even once it warms up so It seems to be headgasket.
Old Dec 28, 2011 | 01:44 PM
exb18c1's Avatar
Why didn't the Honda-tech guy told you to do a traditional test???Leak down and compression tests tell you many things about head gaskets in doubt!when you are doing a compression test is the first reading of the needle that very important!Try redoing it whith the motor at operating temp.
Old Dec 28, 2011 | 03:42 PM
Flipking's Avatar
That test was at operating temps and even at cool temp it didnt show much. But I've been chasing this problem for a week and replacing every part suggested. Lol as I mark off suggestions, the headgasket sounding likely. Last time I started it, it smoked some and the smoke smelled sweet like coolant. Also the last time we pulled the spark plugs, 2 of them had some white on them.
Old Dec 28, 2011 | 03:53 PM
exb18c1's Avatar
which cylinders?
Old Dec 28, 2011 | 05:55 PM
Flipking's Avatar
2 and 3, same 2 that had slightly lower compression than 1 and 4. Did a block test but didnt show much.
Old Dec 28, 2011 | 06:06 PM
exb18c1's Avatar
can you check the coolant sensor for rationality?Temp vs resistance?
Old Dec 28, 2011 | 06:44 PM
Flipking's Avatar
Umm, I wouldnt know how to do that. I appreciate all the advice! Another question I have, if I end up doing the head gasket, what all does everyone recommend doing at the same time. Timing belt, water pump, machine the head. Valves?
Old Dec 29, 2011 | 08:13 AM
exb18c1's Avatar
Do not machine the head unless you have too.was it machined before?
Old Dec 29, 2011 | 11:12 AM
Flipking's Avatar
Not that I know of. I have only had the car about 6 months. I'm going under the assumption that it is the original headgasket and timing belt.
Old Dec 29, 2011 | 11:20 AM
exb18c1's Avatar
What's the milage on it?
Old Dec 29, 2011 | 11:39 AM
Flipking's Avatar
165k
