Obd1 b1 block with obd2 b1 head
Old Dec 21, 2011 | 01:19 PM
osbunjosh's Avatar
Default Obd1 b1 block with obd2 b1 head
I plan on swapping in a b18b1 into my 96 civic dx coupe after christmas. I have been going to a local junkyard and all i can find is a obd1 b1. I was wondering if i could just put a obd2 b1 head onto a obd1 b1 block. Is there any extra sensors or anything i would have to transfer over or just a obd2 head, IM, Fuel rail with injectors?
Old Dec 21, 2011 | 02:05 PM
94dxcoupe's Avatar
Default Re: Obd1 b1 block with obd2 b1 head
The block and head between OBD1 and OBD2 are basically identical other than the black breather box and pcv setup.
Old Dec 21, 2011 | 02:08 PM
apexi_rsx's Avatar
swapping a full obd2 motor would make it easier then doing any combo. the bottom end needs the crank sensor or u can try to bypass it. and ur dizzy will probably be a different plug. u can buy an adapter harness if u got a full obd1 motor. running an obd2 intake manifold would be better to run as for sensors but either will work. u will need to search into it... im not spoon feeding
Old Dec 22, 2011 | 09:08 AM
osbunjosh's Avatar
Okay. Thanks guys. Iv search in google and what not and gathered any important information. I know about the dizzy plugs and stuff. Thanks for the help
Old Mar 26, 2012 | 06:39 PM
maddog4696's Avatar
yo did this problem ever get solved? I'm having to the same one, I just bought a msd OBD2 to OBD1 distributor adapter today, does anyone know if it will work?
beginmyhonda
Dec 3, 2009 02:12 PM
second edition
Jul 15, 2005 04:54 PM
pearl
May 24, 2005 09:38 PM
IntegraTypeR
Mar 19, 2005 04:07 PM
SUPERSONICGSR99
May 14, 2004 05:47 AM
