d15b2 engine to D15b7 trans
Old Dec 21, 2011 | 09:58 AM
phirewire's Avatar
Default d15b2 engine to D15b7 trans
I have a rebuilt D15B2 with an Auto Trans, I wanna put in a manual, would a D15B7 fit correctly? how hard would it be to swap.
Old Dec 21, 2011 | 12:39 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: d15b2 engine to D15b7 trans
The hardest part is sorting out the pedal situation. The transmissions will swap out. you will need the right flywheel/clutch combo for the manual transmission as well.
It is much less drama to just buy a manual car, if you ask me.
Old Dec 21, 2011 | 02:04 PM
jlicrx's Avatar
transmission from D15B7 has a hydraulic actuated clutch and different mounts - to use it, you would need to get a hydraulic to cable conversion kit
Old Feb 10, 2020 | 05:54 PM
Landon Sewell's Avatar
can you please let me know what clutch, flywheel, and pressure plate to use. I just put a 93 trans on my d15b2
Old Aug 11, 2024 | 03:41 PM
92victorysedan's Avatar
what did you end up putting on it? I’m in the same situation. I have a d15b2 motor with a d15b7trans and it doesn’t seem to line up.
Hoopdie91
Apr 16, 2015 09:13 PM
JDMjdw
Apr 12, 2006 06:15 PM
itrcrazy
Jan 26, 2006 05:26 PM
doh boy
Aug 12, 2003 04:36 AM
SlowTec
Oct 2, 2002 04:26 PM
