actual traction bar owners look here
So im thinking of getting one not for the actual purpose of traction but to let downpipes clear. Has anyone actually owned an ebay one? Ive read about 15-20 threads about them but i dont get any good feedback about them being crappy.these are the ones im looking at now.
http://www.ebay.com/itm/89-91-HONDA-...-/260885562913
http://www.ebay.com/itm/1988-1991-Ho...-/230691309101
(Sent from eBay Mobile for Android)
Well they only have a 3 day return policy, so if it breaks you're screwed. 'Light steel' doesn't inspire confidence either. I would look for a reputable one used, or just spend a little more. This isn't a part you want to fail on the street. I've been using the Full Race bar for about 70,000 miles and the moving parts need to be replaced soon. Expect that one to last half as long if you're lucky. JimFab, Innovative, ESP, and Full Race are the only ones I would consider.
There is no stock traction bar. You mean the crossmember? Yes, the ebay ones scare me too. The full race uses the crossmember and tow hook locations. OP, you should really research some more, don't be cheap on this part unless you never drive the car.
Dammit, Wilbur!!! I'm pretty sure I told you yesterday to stay off ebay! Fack!
ETD makes a bomb-diggity tb too! I'm running their latest revision.
I dont wanna pay 300 bucks damnit. I didnt notice.that it bolts to the tow hooks. That killed my interest. Ill look for a used one in the marketplace
Man, if you keep looking for cheap ways out, you'll never be done modding that sedan. Get the goods that will last, bro!
The ETD bar also utilizes the stock crossmember holes. If you buy one used, the possibility of the heim joints being bad is real, which will require you to spend more money. I'll be sending you a bill at the end of this month for my financial advice services.
"Did juu say STEAK?!"
I just looked at that Innovative and I must say... no!
It doesn't even come with adjustable radius rods, so you will have no way of making caster adjustments. I guess they expect you to use your stock rods and give you the option of buying their rod bushings? For not much more, you can have this:
http://www.google.com/products/catal...ed=0CFgQ8wIwBg
It doesn't even come with adjustable radius rods, so you will have no way of making caster adjustments. I guess they expect you to use your stock rods and give you the option of buying their rod bushings? For not much more, you can have this:http://www.google.com/products/catal...ed=0CFgQ8wIwBg
u need to have a cookout damnit, ill bring steak kabobs. Do you have the etd? if so i wanna see how it all meshes together because i also want a half sized radiator.
I run an older model ETD and i havent really had any problems with them... Half rad was a pain in the *** to fit with some custom adjustments but i think thats been fixed now since i bought mine like 4 years ago
If you are going to go the eBay cheap route it is really hit or miss. If you're willing to risk it being a piece of junk but save the money then go for it.
^^^ truth
personal prefrence full-race.
to order call this number: (866) FULL-RACE
to ask questions: (602) 437-2101
ive used a good amount of full race products. they really have a good team making great parts.
i bought it and asked questions later. i ended up returning it for the traction bar. has really bad ground clearance
damn thanks BLU havnt seen your name in a while since i dont post on vadriven anymore. ill just start saving and when i hit 400 bucks ill just pick from there.
do not buy the Innovative front crossmember. i repeat, do not buy the Innovative front crossmember
