99-00 civic si squeaks sometimes
Old Dec 20, 2011 | 12:05 PM
Jdmbryan's Avatar
Icon2 99-00 civic si squeaks sometimes
2000 civic si,lowered on heated springs,yeah i know , but it willl squeak when i turn the wheel to the right or left sometimes, and then sometimes it wont it'll just go away but then come back later on. is it my heated springs that may cause this or what should i look for? doesnt sound like my tire is rubbing on fender or anything like that.
Old Dec 20, 2011 | 12:11 PM
EGLivin's Avatar
Default Re: 99-00 civic si squeaks sometimes
It could be your heated springs. Thats a very good place to start looking. Park your car and turn your wheel to about where you hear the noise. Then get out and put some weight on that side of the car and see if you can replicate the noise. If you can do that then have someone else look and listen as you make the noise. Thats your best way to check. Otherwise the list is long. Could be bushings that now have added roation/ strain on them from lowering your car. Could even be as simple as when you were lowing your car you adjusted your dust plate on the back of your brakes and now that is slightly rubbing when you turn your wheel.
Old Dec 20, 2011 | 03:32 PM
EsotericImage's Avatar
Retired Moderator
if you have any poly bushings, they squeak all the time.
sometimes my ride sounds like a 82 econoline FML
Old Dec 20, 2011 | 04:01 PM
KandabashiDevil's Avatar
Check to make sure the springs are seated properly on the perch! Low quality springs tend to bounce around more, and may become dislodged. They squeak and squeal until finally settling back into place (until they bounce out again).
Old Dec 20, 2011 | 05:10 PM
Mopagan's Avatar
This time of year my car sounds more like bed springs.
Old Dec 20, 2011 | 06:01 PM
L0WL1FE's Avatar
most likely the springs
Another_Si_Guy
23
May 19, 2015 05:59 AM
FTNW
Jul 7, 2012 04:32 PM
dgaleno
Suspension & Brakes
Apr 30, 2012 01:34 PM
Tuner Eddy
Mar 1, 2005 10:48 PM
LilDevil
Dec 23, 2001 07:02 AM
