ideas for holding pipe
Old Dec 19, 2011 | 04:53 PM
1QwIkEf's Avatar
From: R.I.P Brian Arbogast...you will be missed, maryland, USA
Default ideas for holding pipe
How do you guys hold your pipes to get a tack on them.. I know someone has to sell something or some of you guy have built something.. looking for ideas .. help a noob welder out..
Old Dec 19, 2011 | 05:11 PM
91jdmhatchback's Avatar
Default Re: ideas for holding pipe
I use my hands when tacking.
Old Dec 19, 2011 | 05:51 PM
1QwIkEf's Avatar
Yeah but sometimes that's almost impossible
Old Dec 19, 2011 | 06:08 PM
hootiehoo's Avatar
http://www.vansantent.com/welding_ac...ice_clamps.htm
http://www.vansantent.com/welding_ac...ipe_pliers.htm
im awesome
Old Dec 19, 2011 | 06:13 PM
Mr. Moose's Avatar
The options depend on what kind of pipe you're talking about. Pipe fitters who weld large iron pipe have a variety of (expensive) specialized fixtures available to buy and some make their own custom ones as well.
If you're talking about schedule pipe the size used in car manifolds, there are different options. A few are the adjustable clamps made by icengineworks like here: http://www.summitracing.com/parts/EVT-2000TTWCS/, or stainless steel exhaust band clamps with an access hole cut for use in tacking, holding the pipe in a pair of pipe pliers like these: http://www.stronghandtools.com/produ...g/pgv_pic.html or just on a single or set of pipe positioners like here: http://www.vansantent.com/tube_positioners.htm
Or, you can just put them on a table, put a couple of large metal blocks on the sides of them, and tack away
Remember to get a good ground setup before you hit the pedal.
Old Dec 19, 2011 | 06:20 PM
Boosted_B_Series's Avatar
These are what I use
Old Dec 19, 2011 | 07:02 PM
EJAYATE's Avatar
I Deliver
I made this thing out of angle iron so the pipes dont roll around. Usually just hold the part im tacking in my hand. I will use welding rod to gap the pipe and foil tape to hold it together sometimes.
Old Dec 19, 2011 | 08:00 PM
1QwIkEf's Avatar
Nice.. that's what I'm talking about. I knew someone had to make something like that. I just couldn't find it
Old Dec 20, 2011 | 12:14 AM
Sobe_Death's Avatar
Originally Posted by Mr. Moose
...or stainless steel exhaust band clamps with an access hole cut for use in tacking...
This is what I use on all but the tightest radii, but otherwise it's handheld!
Old Dec 20, 2011 | 04:31 AM
weiRtech's Avatar
OG Fabricator
i use my hands. it should be possible to fuse tack for just about all applications if the fitup is correct. i also have a vise and a variety of blocks/v-blocks that i can use to prop odd shaped parts to have access to hard to reach areas.
hondaapi
Welding / Fabrication
Jul 4, 2006 08:21 PM
r0yal
Apr 19, 2006 07:03 PM
tonezilla
Feb 15, 2005 07:17 AM
G6-Civic
Oct 6, 2004 03:22 PM
Etylorcen
Mar 20, 2002 11:20 AM
