busted engine that needs a swap what do i do?
Old Dec 19, 2011 | 09:35 AM
MayorMcCheese's Avatar
Default busted engine that needs a swap what do i do?
i literally have no idea where to start
im MayorMcCheese lol i own a modded 08 accord V6 6 speed
my buddy has a EP3 that needs a engine swap water got into the engine from a good rainstorm in NJ and engine is shot .. so he needs a new engine.. i kno very little of K20 and K24 engines but he wants to swap it what specific engine can just be direct swap out? does he need Kpro ?
hes not looking for a turbo car down the line just a practical car like he originally had before this rain storm
what are his options he can do and where can i get cheap engines?
Old Dec 19, 2011 | 02:43 PM
Type-Spaz's Avatar
DC5/EP3 MOD :)
Default Re: busted engine that needs a swap what do i do?
the easiest swap is to stick with the same engine... so find a base model EP3 K20A3 engine. I get my engines from LKQ. You can find them on the web.
If he wants more power and high RPM go with a k20a2 or k20z1 from the RSX-S and you'll need kpro. If you want more torque for his little mini minivan then get a k24a2 and kpro. Either way if you go with one of these swaps or the several other options like a k20/k24 frank build sounds like you have a lot of homework to do.
Old Dec 20, 2011 | 06:27 AM
turboteg2nv's Avatar
Wow.. for once I disagree with Spaz.
I would swap in a K24A4/8 engine from an Accord. They can be found for the same price as the K20A3 engine. More torque. Do it.
hmotorsonline.com
Old Dec 20, 2011 | 07:09 AM
spatula's Avatar
Not sure where you are in NJ, but in the philly craigslist I recently saw a k20a3 going for $450. I did a search for "si" and found a partout thread.
Old Dec 20, 2011 | 07:59 AM
Type-Spaz's Avatar
DC5/EP3 MOD :)
hmotorsonline.com
he said "easiest" and from the sounds of his thread he hasn't researched at all... so I gave him an honest answer... easiest would be bolt and go stock for stock...
Old Dec 20, 2011 | 03:06 PM
Kidnkorner's Avatar
You can get the same engine for around $700-$800, any Accord engine will swap right in with a CRV side mount though you will need K pro to get the right AFR.
For power and a straight forward swap get a K20A2, you DONT need Kpro to swap that in but you will need the ECU for that engine.
Old Dec 22, 2011 | 07:15 AM
WhiteOnRice's Avatar
If you want cheap, go with another a3
If you want a swap do want teg said or go with a k20a2 swap (won't need kpro)
Old Dec 22, 2011 | 04:02 PM
turbohatchBnuts's Avatar
just swap the k20a3 back in there. it would be the most cost effective swap i think.
Old Dec 23, 2011 | 07:34 AM
hayabusa750's Avatar
I live in jersey have a o5 ep3 k20 engine has 35k for 450 . I live in teaneck new jersey 07666
motorsportkyd
Jul 14, 2013 10:25 PM
FrederickRighteous
Jan 24, 2009 07:08 PM
blkonblkhatch
Mar 8, 2006 07:15 AM
