Horn; Overheating; Clutch problems.
Old Dec 18, 2011 | 12:33 PM
Jabuuty671's Avatar
Default Horn; Overheating; Clutch problems.
There are a few things with my 1999 Civic I bought and need to fix immediately because the registration expires next month;
1) Horn; It works when I tested it with a wire to the battery but I just don't know how the wiring for the horn looks; can somebody take a picture of theirs?
2) Overheating; I've flushed the radiator and engine block; removed the thermostat. I have yet to replace the belts and I'm assuming that's the case because there's also a groaning/humming/buzzing sound from the belts closest to the water-pump. Either the water pump is bad or its just the belts that are defective. Other than that; I haven't tried a new radiator cap simply and the guy who sold it to me bought it from another owner who was in a front-end collision and pretty much rebuilt the whole engine bay. Also, there are so many vibrations from my car which make it sound like it's going to fall apart; could be the poor mounting of the radiator and grille and hopefully not bad engine mounts because it's not as likely.
3) Clutch; when I press in my clutch it screeches/squeaks. I've heard it may be the Pilot bearing, is that right? Might as well get a whole new Clutch Kit. Also when I go into reverse I don't know if it's normal to play with the shift **** a few times for the transmission to get into Reverse but it's normal for me; and when I'm reversing it feels like I'll always stall out no matter the amount of gas I press.
I'll post pictures and videos later. Thanks
Old Dec 18, 2011 | 02:11 PM
apexi_rsx's Avatar
Default Re: Horn; Overheating; Clutch problems.
if it sqweeks only when u press the pedal and release it then u may just need some grease on the end of the slave cylinder push rod on the little ball. id just get a head gasket,and timing kit and do it all at once so u know u have no problems whether its the water pump or head gasket because u will replace both.
TheWizard14
Sep 7, 2015 01:34 PM
Matewos
May 3, 2015 07:10 PM
kaison
15
Jul 2, 2012 01:08 PM
PhoenixDownVII
Oct 24, 2006 08:04 PM
