Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Motor oil for a 03 em2?
Old Dec 17, 2011 | 11:04 PM
trunkluv's Avatar
Default Motor oil for a 03 em2?
Was curious my lady just got an 03 coupe and not sure what motor oil she sould run bone stock commuter for her and i run 10w30 in my 94 use same stuff? wheres a good place to get something to cover up the holes of where the spoiler wont be soon?
Old Dec 17, 2011 | 11:59 PM
It Wasn't Me's Avatar
Default Re: Motor oil for a 03 em2?
5w20
It says it right on the oil cap.
You can buy plugs for the trunk lid.
If she's selling the spoiler to someone, why not just swap trunk lids? That way they don't have to drill, and you don't have to drive around with plugs in the trunk lid.
Old Dec 18, 2011 | 10:21 AM
EM2abe's Avatar
you can also use 0w-20 just as well as 5w-20. its thinner at standing temperature so it lubricats the internals a lot better at startup. but its a bit more expensive. 5w-20 will do just fine if you're an average joe.
Old Dec 21, 2011 | 02:30 PM
graham b's Avatar
i just got a o4 today!!!
what is the best brand you guys use? and synthetic or no? im not sure what the prev owners used..
Old Dec 21, 2011 | 02:38 PM
90civicstdgold's Avatar
We always use Chevron 5w-20 at the shop. Non Synthetic
Old Dec 21, 2011 | 10:45 PM
em2boy36's Avatar
mobil 1 fully synthetic !!
Old Dec 22, 2011 | 12:11 PM
graham b's Avatar
i always hear not to switch from reg to synthetic or vice versa. whats the harms of switching over to synthetic if ur car has been running with regular oil??
Old Dec 22, 2011 | 01:12 PM
toyomatt84's Avatar
Sanji
Any oil seal that has been using standard lubricant for an extended period of time will be altered by the sudden change to synthetic. This will cause an increase in oil burn and a decrease in performance and economy.
Old Dec 23, 2011 | 04:10 AM
GriFFIthS's Avatar
I always use 10w30 plus an oil stabalizer to cut down on oil burn off.
Old Dec 23, 2011 | 08:03 PM
bk7794's Avatar
I thought that was a myth or was the case years ago. But the modern day synthetic oils can be mixed.
Old Dec 24, 2011 | 12:59 PM
graham b's Avatar
So if it's the sudden change that messes it up, could I gradually switch over starting by using a synt blend? Or just stick with the regular is my best bet?
Old Dec 24, 2011 | 06:58 PM
toyomatt84's Avatar
Sanji
Synthetic oils can be mixed with other synthetics, typically without complications. Switching from a natural oil to a synthetic (or vice-versa) is where you run in to issues with the seals. This is not a myth, in case you were wondering.
Why does it matter so much? You won't gain anything performance-wise from changing over to a synthetic blend. Especially not on a factory D17. If you were to build the engine up for a higher compression or for a turbo setup, then it'd be a wise investment to run a nicer synthetic oil. But, for the uses you will have for the stock drivetrain, there will be no tangible difference between the standard oils and synthetic.
Old Dec 25, 2011 | 08:21 AM
graham b's Avatar
I'm not so worried about the performance. I just want my car to last as long as I can make it, I just figure the synt is of higher quality and would extend the engine life.
Old Dec 25, 2011 | 04:02 PM
toyomatt84's Avatar
Sanji
To be honest, you'll be fine with a standard oil if that is what has been used in the vehicle all this time.
Old Dec 26, 2011 | 01:00 PM
graham b's Avatar
Sounds good to me! Thank u kind sir
Old Dec 29, 2011 | 03:12 PM
Traum's Avatar
Not to dismiss Matt's comments or anything, but when I bought my 04 ES1 with ~180k km (~112k miles) on the odo, I switched from the previous owner's 5W20 dino oil to 5W20 synthetic, and there was a small but noticeable difference in performance, NVH, and gas mileage. The engine revs smoother and easier, the car idles smoother, morning starts were easier, and gas mileage improved very slightly (though this could well fall within the regular variable range from regular driving). I also have no leaks from the car. But on this last point, I have to emphasis that I might have been a luckier case -- a good number of people that I know discovered leaks in their cars after switching to synthetic on an older engine.
I've had a similar experience with another car that also switched from 5W20 dino oil to 5W20 synthetic, although that car was at a significantly lower mileage (15k km, tops) when the swtich took place.
For me, the biggest benefit for switching to synthetic was the extra smoothness.
-Lik
Old Dec 29, 2011 | 03:36 PM
toyomatt84's Avatar
Sanji
-Lik
As with many things, some people experience differences that are noticeable. But, there's no guarantee that he will see the same results. Also, there are quite a few risks (as noted above) to switching oil types. When I still had a D17, I did switch from conventional oil to a Mobil1 synthetic and noticed no change what so ever in engine performance or how well the engine ran. It was merely a change for ease (I had access to a lot of Mobil1 synthetic at the time, and it was cost efficient). I did the change-over at 30,000 miles.
oramac_eg
27
Oct 19, 2008 10:55 PM
zoso
Jun 24, 2008 02:21 PM
AW
Jul 11, 2004 10:35 PM
Fuster_Cluck
Nov 24, 2003 10:45 AM
JDMINTEGRAGUY
Feb 13, 2003 03:31 PM
