99 acura 2.3cl timing belt help
Old Dec 17, 2011 | 10:07 PM
seabee2011's Avatar
Default 99 acura 2.3cl timing belt help
I have a 99 2.3 cl. I just took it to get the timing belts replace and the pully, car was running smooth before, after it got changed car started to vibrates too much, does the car needs to be timed again
Old Dec 18, 2011 | 05:54 AM
Lost Again's Avatar
Default Re: 99 acura 2.3cl timing belt help
Sounds like it "could" be the balance shaft out of time...or a number of other things that might have been left loose during the job.
Old Dec 18, 2011 | 06:03 AM
GhostAccord's Avatar
Take it back where you got the work done and ask them to fix the problem. If it has to do with the belt job they shouldn't charge you anything.
Just out of curiosity, where did you take it to get the work done? Is it a place that normally works on a lot of Honda/Acura vehicles? Not that it should really matter if they have good knowledgeable mechanics.
Old Dec 19, 2011 | 01:11 AM
seabee2011's Avatar
I took it to jersey city, and i talk to the mechanic and he'll be coming to check the car at my house. One thing i noticed when he was putting the botton belt , was that the oil pump mark on the teeth was pointing up and the rear balancer mark was also pointing up. Is that how is supposed to be time?
Old Dec 19, 2011 | 04:15 AM
djkurious's Avatar
Originally Posted by seabee2011
One thing i noticed when he was putting the botton belt , was that the oil pump mark on the teeth was pointing up and the rear balancer mark was also pointing up. Is that how is supposed to be?
Yes
Old Dec 19, 2011 | 06:06 AM
Yes, the crank pulley, cam gear and rear balance shaft gear timing marks all point up. However, the front balance shaft gear timing mark points to the front. There is a timing mark on the oil pump housing that you line it up with.
Old Dec 19, 2011 | 08:30 AM
seabee2011's Avatar
Yes i see that. i saw the mark on the oil pump housing facing right towards the rear balancer shaft.Will that cause any big damage?
Old Dec 19, 2011 | 09:42 AM
Damage, not right away. Shaking engine "vibrations", Yes.
Having your balance shaft out of alignment will cause the vibrations that it is made to chancel out, even more pronounced. Over a long period of time it could cause some extra strain on bearings and the oil pump if it vibrates too much.
Old Dec 21, 2011 | 02:46 PM
seabee2011's Avatar
I got my car back today and told the mechanic to align the oil pump housing with the engine block and align the rear balancer through the maintenace hole, car now runs good,no more vibrations....thanks for the advice
Old Dec 21, 2011 | 10:11 PM
Hairnandez's Avatar
sucks that you have to tell a mechanic how to do their job.
mjb9369
Jan 19, 2017 07:53 PM
Toy Power
Mar 13, 2009 05:52 AM
b18LS
May 2, 2007 11:11 AM
Jeff99Base
Sep 15, 2003 05:00 AM
