seriously dont know why it wont start
Haven't put extra gas in but took the injectors out one clogged put them back in tried starting nothing then listened for pump to kick on and nothing doesn't turn on when key is on 3rd click could that be a relay or just the whole pump? I just don't understand how it could bw the pump seeing as when I did the filter there was gas shooting out the lines
Try switching out ur ignition switch....i had a similar problem where my car wont start and sometimes it would randomly shut off while driving...switched out my ignition switch and solved the problem
Today I was driving down the road in my Honda Prelude and it stalled on the F'ing freeway, I had to tow it to PEP boys and they told me I need a new engine, It wouldn't turn over but the battery would still work
Just because a motor won't turn over doesn't mean you need a new engine
I'm not sure I'm understanding what your saying to do take out my main relay? Cuz i was thinking of just checking my fuel pump relay and if thats good do one more check to hear if my pump kicks on and pressurize before starting
You took it to a parts store for diagnosis? Take it to someone who knows what they're doing.
((((( cuz it wont turn over booooo
Run a good ground to pin 2. I just had the same problem with my 93 prelude. Fuel pump wouldnt turn on when key is on. ran a ground and it started right up.
Dan in Jupiter
Dan in Jupiter
I ran a ground from the chassis(wrapped a wire around the trunk release bracket as it was there and easy as the interior was out of the car) to pin 2 of the main relay, it is a solid black with silver dots on it. see the diagram above. When I posted about my issue, a few guys said this relay and connectors go bad.
Dan in Jupiter
Dan in Jupiter
Dan in Jupiter
Dan in Jupiter
if not going to be getting a pump
So referring to this picture I ripped the under dash apart and cannot find the relay anywhere do you guys maybe have a self picture you took yourselves that could be a little more descriptive of where it is pleas
So finally got my relay out and it doesn't look like any of the joints of the sauter are messed up heres a pic let me know what you think
