Turn signal & hazard are intermittent
Old Dec 17, 2011 | 11:23 AM
Paul 631's Avatar
Default Turn signal & hazard are intermittent
Hey all,
My turn signals and hazards,when on, and fairly random: more like sending out Morse code than doing their more regular jobs.
Since they occasionally work, it can't be the fuses; I checked and confirmed the fuses are intact.
So it's either replacing the turn signal stalk & switch, or replacing the turn signal relays?
Hopefully this also solves the same issue with the hazards??...
Are the turn signal relays the two black relays in the fuse locations underhood, or are those solely for the headlights?
Any other theories or solutions?
Thanks!
Old Dec 17, 2011 | 06:34 PM
Type-Spaz's Avatar
DC5/EP3 MOD :)
Default Re: Turn signal & hazard are intermittent
I would start with the relays. You can test them by swapping them out with a different relay for something else that has a matching relay
Old Dec 18, 2011 | 06:45 AM
Paul 631's Avatar
3-hrs electrical troubleshooting but no success removing the relay, seems like I'm going to have to read up on how to take the dash apart...
EDIT: apparently the entire fuse/relay box might slide down after removing the bottom/right bolt, I'll check it out tomorrow...
In the meantime, the turn signal / hazard relay part is # 38300-S5P-A01.
Old Dec 18, 2011 | 03:08 PM
Type-Spaz's Avatar
DC5/EP3 MOD :)
The fuse box will drop down yes.
Old Dec 25, 2011 | 07:19 AM
Paul 631's Avatar
The signal/hazard relay finally shipped & installed, problem solved!...
Chris09
Jun 9, 2022 08:05 PM
lien
24
Nov 30, 2021 04:10 PM
stops
Lighting
Jun 8, 2015 06:24 AM
JTR
Jan 11, 2015 04:33 AM
gnxpro24
Feb 2, 2011 03:52 PM
