98 Civic Distributor - I can't get rotor off the shaft
Old Dec 16, 2011 | 10:21 AM
alcor4ever's Avatar
Default 98 Civic Distributor - I can't get rotor off the shaft
Guys, I need your help please!
I couldn't get the rotor off the shaft... I have taken out the screw but it seems to me the rotor is stuck with the shaft... I ended up breaking a piece off the rotor when prying... now I have the whole distributor off...
Any comment will be greatly appreciated!
Old Dec 16, 2011 | 10:32 AM
alcor4ever's Avatar
Default Re: 98 Civic Distributor Motor
Is it possible that the plastic rotor could melt? Now I regret trying to replace the rotor. It could have been still good...
Old Dec 16, 2011 | 11:25 AM
Jdubbs6101's Avatar
Well if it's stuck on you have to get it off. Douse the thing in wd-40 and try again after it has sat for a few hours. Good luck
Old Dec 16, 2011 | 12:52 PM
94EG8's Avatar
Seagull Management
They frequently seize on the shaft. Use a hammer and flat screwdriver to knock it off, it will break.
Old Dec 19, 2011 | 11:13 AM
alcor4ever's Avatar
Default Re: 98 Civic Distributor - I can't get rotor off the shaft
Thanks guys! I managed to nip the rotor off piece by piece. After I was able to take out the leak cover, I just pried the center off the metal
Is it ok with a slightly cracked leak cover though?
Old Dec 19, 2011 | 03:36 PM
morbius18's Avatar
Mine was the same when i was changing the internal seal. I havent had any problems.
slowcivic2k
10
Jan 17, 2009 03:35 PM
sleepyhamsterlx
Jul 3, 2006 08:25 AM
93H22ACX
May 24, 2004 02:32 AM
toooslow
Jun 11, 2003 11:20 PM
vtec.dc2
Aug 24, 2002 11:51 AM
