2002 Accord parts id help
Old Dec 16, 2011 | 09:01 AM
bw77's Avatar
Default 2002 Accord parts id help
I've got a 2002 Accord EX 4-cyl auto.
I've been trying to learn more about the car, and one problem I have run into
is identifying some of the parts. I have the Haynes manual, but it is not very good about showing where some parts are located. I have also looked at the parts diagrams on the web and they are hard to use, too.
So I posted this pic on the web. Can someone help identify the numbered
parts? Thanks.
http://s741.photobucket.com/albums/x...t=IMG_1608.jpg
Here's what I have so far.
1- fuel pressure regulator
5- vacuum hose going into fpr
6,8 - cables going to throttle body(from where?)
Old Dec 16, 2011 | 01:41 PM
bw77's Avatar
Default Re: 2002 Accord parts id help
2- fuel pulsation damper
3 - fuel feed hose
6,8 - cables from gas pedal and cruise control
7 - IAT sensor
Old Dec 16, 2011 | 01:43 PM
v4lu3s's Avatar
RTFM
i believe 4 is your vacuum source for the egr system system
Old Dec 17, 2011 | 06:44 AM
bw77's Avatar
4 is connected to the top of a large, black, round canister on the pass side of the car, under the fuse box. The canister is #10 in this pic.
http://s741.photobucket.com/albums/x...t=IMG_1614.jpg
There is also a vacuum line coming into the top of the canister.
Anyone know what that canister is?
Old Dec 17, 2011 | 07:50 AM
v4lu3s's Avatar
RTFM
charcoal cannister. you know some of this stuff is also usually on the emissions sticker under the hood. that would also mean that line 4 is for the evaporative purge system NOT the egr (which means the egr is completely electronic if my memory is not acting up again).
Old Dec 17, 2011 | 08:39 AM
bw77's Avatar
The evap canister purge valve is #11 in this pic:
http://s741.photobucket.com/albums/x...=IMG_1618.jpg&
And it does not appear to be connected to the black canister #10.
Here's a pic of the hood diagram:
http://s741.photobucket.com/albums/x...=IMG_1621.jpg&
Old Dec 17, 2011 | 09:30 AM
poorman212's Avatar
automanualsource, bet it will be the best $22 you ever spend.......
Old Dec 17, 2011 | 11:51 AM
bw77's Avatar
Thanks for the tip. I had not heard of that one before. Looks like a PDF version of the Helms manual?
Old Sep 6, 2013 | 04:08 PM
womble3333's Avatar
http://mail.aol.com/38023-111/aol-6/...Inbox&partId=1
can anyone tll me what this is 02 accord coupe behind rt side inner fender
Old Mar 8, 2014 | 09:03 AM
bw77's Avatar
Answering my own question here, 2+ years later, #10 is the vacuum tank for the cruise control (auto trans), and #4 is the vacuum line going from the tank to the cruise unit.
Oldskoolhondas
Classic Hondas
Oct 19, 2015 08:19 PM
skyler84
Jul 19, 2013 06:38 AM
LOLA-92
Jun 19, 2009 08:06 PM
Delano5050
Jan 8, 2007 05:06 PM
