GA Ek Hatch B16B DAP clean/tucked w/AC
SOLD.......
Its time to sell one of my toys. This car was all original when i got it, I have done all the work to it myself. Everything works perfect, no problems. runs great
The car has a B16B swap with low miles with the matching transmission w/lsd
New oil pan gasket, cam seals, valve cover gasket, Timing belt & tensioner, water pump, thermostate
Motor has a ACT streetlight flywheel and a ACT 6 puck clutch
Hasport polished motor mounts
New Vteckidd Header
New Apexi World Sport II exhaust
Fresh paint on exterior and in engine bay It was sprayed with PPG global paint and PPG 2002 clear
New Axles
New Radiator
New electric fan
New upper and Lower ball joints
New outer tie rods
New front Rotors and Ceramic pads
Front knuckles were taken apart and sandblasted and painted like new
New master cylinder
New brake booster
New ac drier
New Goodyear gatorback drive belts
New custom Brake lines with earls fittings
New stainless braided teflon coated clutch line
New clutch slave cylinder
All bolts under hood are new zinc plated
New distributor
New alternator
New throttle cable
New braided fuel lines with cartridge fuel filter
New Headlights
Sir front and rear bumpers
New mugen style front lip
New CTR style rear lip
Battery relocated in trunk
Wheel wells sand blasted and under coated
Hid hi/lo Headlights
JDM fog lights
JDm optional Momo factory steering wheel
Civic SI cluster
CTR red Carpet
Socketed P28 converted to OBD-1
Full wire tuck
T1R fully ajustable coilovers
Car has ICE COLD AC
LED tag lights and dome light
Very clean interior
The car runs great, I have barely driven it since i put it together 2 years ago. There are no problems with the car at all, No check engine lights.
The windshield has scuffs from the wiper blade, it was like that when I got it, and the front lip came is missing some paint due to parking lots.
All parts were new 2 years ago, I have put less than 6,000 miles on the car since all the work was done.
The car will not come with these wheels on it.
New Vteckidd Header
New Axles
New Radiator
New electric fan
New outer tie rods
New master cylinder
New brake booster
New ac drier
New distributor
New alternator
New throttle cable
New Headlights
JDM fog lights
Civic SI cluster
CTR red Carpet
Full wire tuck
Car has ICE COLD AC
Very clean interior
